Question about Fahrenheat F2543 Baseboard Heater
Tripping breaker wired black wire to black and white to other black and then the ground turn on and bam trip my 200amp house service breaker whats up with that ??
  • 20 Answers
What were you wiring? Usually the white wire is a neutral which is connected to a white wire or your neutral bar in the panel.
sounds like you either "crossed-phases", connected a red and black wire together somewhere or you have a "ground fault", a hot wire is somehow contacting something connected to ground or neutral.
would you write me back and let me know what you were installing and what you did other than what you wrote here so far.
Posted on Mar 31, 2009
Our 7788F keeps going into a ground fault condition. Need help troubleshooting. John
Ground Fault ???
Troubleshooting Ground Fault
Troubleshooting a ground fault circuit interrupt, or GFI, breaker is pretty straightforward. Troubleshooting the circuit itself can be quite time-consuming.
The GFI breaker is designed with a test button incorporated into the breaker itself.
Pushing the test button should trip the breaker.
On GFI-style breakers the neutral wire going into the house's outlets is connected to the breaker's neutral connector, the white neutral that comes out of the breaker is connected to the neutral bus in the panel, isolating the neutral bus from the neutral wire going into the house.
The test button actually shorts the neutral wire feeding the circuit to the neutral bus in the electrical panel creating a ground fault that should trip the breaker.
It is considered a ground fault because the neutral bus in the main electrical panel is actually connected to the ground bus through the panel's metal casing. What to do if the test button isn't tripping the breaker
Push the test button on the GFI breaker.
The breaker should trip.
If the breaker does not trip, then it may be that the breaker has already tripped and just looks like it's on.
The position of the switch may only move slightly from the on position towards the off position when tripped.
Push the switch on the GFI breaker all of the way toward the off position.
It may take some force to get the breaker to reset.
Turn the breaker back to the on position.
When the breaker has been reset properly you should feel some resistance when pushing the switch back on.
3 Push the test button again and the breaker should trip.
If the breaker still doesn't trip then you should test for power at the screw connections inside of the electrical panel.
Remove the screw that holds the dead front covering the breaker's connections.
Remove the dead front cover.
Test for power with your voltmeter set on AC volts on the highest scale.
For a single pole GFI breaker, touch the black lead from the tester to the silver screw on the GFI breaker and touch the red lead from the tester to the brass screw on the GFI breaker.
You should see 110 volts on the tester. If voltage is seen but the test button won't trip the breaker, then the breaker is bad and should be replaced.
5
Test for power on a two pole breaker by touching the red voltmeter lead to one of screws with a black or red wire connected to it.
Touch the black lead to the other screw with a black or red wire connected to it.
You should read 220 volts or close to it on your voltmeter.
If you read voltage and the test button won't trip, the breaker is bad and needs to be replaced.
What to do if the breaker won't reset and keeps tripping when turned on
6
Unplug everything that is plugged into any of the outlets on the circuit in question.
Try resetting the breaker again by pushing the switch all the way to the off position and then turning it back to the on position.
If it won't reset and trips when the breaker's switch hits the on position, it could be a bad breaker or a problem in the circuit itself.
7
Use your straight-tipped screwdriver to loosen the brass connection screw or screws on the GFI breaker.
Pull the black hot wire, or wires, out of the breaker's connectors.
Loosen the silver screw the white wire is connected to and remove it from the GFI breaker.
8
Push the switch all the way to the off position.
Turn the switch back to the on position.
If the breaker still won't reset, then the problem is the breaker itself and it should be replaced with a new one of the same size, brand and model.
If the breaker resets normally and the test button trips the breaker when pushed, the problem is in the circuit itself and an electrician should be called to find your ground fault.
9
Reconnect the black wire, or wires, to the brass screws on the GFI breaker.
Reconnect the white wire to the silver screw on the GFI breaker.
10
Replace the dead front cover into the breaker panel.
Install the screw or screws that hold the dead front in place.
http://www.hilo-electric.com/blank?pageid=63
Aug 14, 2013 | Computers & Internet
Where is the main switch to shut off the power in the house? I was vacuuming and the power went out in various areas around my condo. I think I have isolated the breaker and want to change it but I do not...
In some condos/apartments the main breakers are located outside. This is because the meter and incoming service are some distance from the local panel. Perhaps your breaker isn't bad, but the additional load of the vacuum caused it to "trip" Unlike some brands the Bryant don't show a trip indication other than the handle moving. Try turning this breaker completely off, ( if it was tripped, it will click) then turn it back on. If you do locate the main outside, and decide to change the breaker inside, be sure to "lock out" the main disconnect while you're working on the panel.
Nov 11, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
Red lite on the straight blade indicator plug (PS5266XGCMCCV4) This is a line that runs under ground to an outdoor chicken coop. I'm sure the wiring is correct, if black plasticed wire to brass screw...
You have the connections correctly done. I hope that you ran the wires through plastic conduit for the under-ground run. What is connected at each end? Is the circuit causing the source breaker/fuse to trip? Are you making direct connection to your house service panel or just plugging the extended wiring into a socket in the house? The hot black wire should go to the breaker/fuse, the white wire should go to the neutral bar, and the ground wire should go to the ground bar. Hope this makes sense and helps!
Nov 06, 2010 | Garden
Breaker keeps tripping when turning on pump.
The red and black wires if ran correctly are the load lines(power). The white is neutral or ground. If its a 1/2 to1-1/2 hp motor connect the red and black wires to terminals #1 and #4. If its 2 hp use #1 and #4. If its 3 hp use #2 and #4. Connect the white wire to the green colored screw. A grounding conductor should always be connected under the green grounding screw, which is located within the terminal compartment of the motor. You can check the breaker for the wire colors, one should be black and the other red. The white wire should be terminated to the neutral/ground bar in the can.
May 16, 2010 | AO Smith 1 HP 115/230V 56C Replacement...
Tried to install a ceiling fan to replace a dimming light chandelier.......light on fan and fan itself works but only by the pull chains....it will not turn off or on by the wall switch that controlled the...
Trip the breaker and verify that the fan/light will not operate. If tripping the breaker kills the circuit and flipping the wall switch would not, the switch is probably bypassed. Place the wall switch to "off" with the breaker tripped to the "off" position as well. Gain access to your wiring connections at the fan. Look for a single (black) wire that is not connected. This should be your hot return from the wall switch Make your fan/light connections to this wire. (Are you sure that the ground wire that you connected is a ground? If it is, it should be bare copper with no insulation). Your white (neutral) connection to the three white wires should be fine. If you don't find a single wire in the ceiling box, call on an electrician. Regards --WoobieDog--
Jul 07, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
200AMP Breaker trips same time every night
Something doesn't sound right here. You indicate 2 200Amp breakers. With a single service entering the house, this is not possible. The "sub-panel" to the pool house is more likely a 100Amp setup, yes? If not, you have a bad setup and it should be corrected. I would suspect that you are attempting to pull too much current to the pool and that is what is tripping the breaker. Also, these breakers should not be run over about 80% of their capacity for the long haul. If they are, they tend to age and get either real sensitive causing tripping when it shouldn't or you can run 500Amps through it and it won't trip.
My suggestion is to revisit the setup. If the pool house is fed from the main panel, make sure that the breaker for it is not 200Amp. Second, try disabling the pool house breaker to see if that is the source of the problem and look more closely there.
Keep us posted.
Dan
Jun 29, 2009 | Electrical Supplies
New Kenmore refridgerator trips circuit breaker
1. Check to make sure the receptacle is wired correctly. Black wire goes smaller of two inlet holes, white goes to the larger.
2. Check to make sure that the smaller blade of the 2 prongs on the ref. plug is not grounded. Use ohmmeter from smaller blade to fridge housing
Apr 25, 2009 | Kenmore Refrigerators
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Generator electrical
On a 230 volt std hook up here's the way it is supposed to work. From black to white you should get 115 volts. From Red to white you shoudl get 115 volts. From red to black you should get 230 volts.
Concentrate on getting the correct output from the generator with the load to the house disconnected
This should be 115v (black to white, 115 volts red to white and 230 volts red to black.
On the load side (ie, the house connected) what are you using? 115 volt lights, etc on one side of the
230 volts, and some other 115 volt loads on the other side.. Are there any 230 volt loads. It could be
that one side of the 230 volts (ie, a 115 volt side is drawing a lot more current than the 2nd 115 volt leg.
Get back with me on just what the loads are botth 115 volt and 230 volt . also what are the rating on the circuit breakers.
Loringh
Oct 28, 2008 | Electrical Supplies
Fahrenheat F2543 Baseboard Heater Logo
156 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
