Question about JVC GR-D22U Camcorder
Please wait, condesation, operation paused
I was going to use the dv camera and it won't take a tape, keeps giving message about condesation
  • Anonymous Dec 28, 2008
    Operation Condensation causes me never to be able to use the camera
Posted on Dec 11, 2008
When on sreen says please wait condisation operation paused wut do i do thank u
Condensation can form inside the camera if you take the camera from one environment to another where there is an extreme temperature change.
Simply wait until the condensation disappears. The warning is to protect tape and camera.
Feb 18, 2011 | JVC Cybercam GR-D30 Mini DV Digital...
I am having JVC d50 mini dv camcorder. i am getting message as "please wait, condesation' I switched it on for several hours and switched it on still this message is there. During message the...
your dv cam sensed a condensation means some moist is inside the unit, to protect the sensitive electronics on it. it disabled normal function of the dv cam. try to avoid placing the dv cam from sudden cold area to hot area, or vice-versa do not use dv cam until condensation message is gone
Feb 15, 2011 | JVC GR-D50 Mini DV Digital Camcorder
Condensation operation paused
Remove power from the camera. I remove the battery as well. In the back of where the tapes go, on the left side is a silver component. It's just behind a metal roller that hangs down from a plastic piece over the head. If you look behind the roller diagonally across where the tape goes, you can see a black square on the right side of the silver component. Clean this (gently!) with a moist cotton swab. The swap should get a bit of black gunk off. I'd recommend cleaning it with a dry swab next to remove any moisture. Wait a minute or so to be sure it's dry. Then re-apply power. You should not see a false condensation message for a long time.
Mar 13, 2010 | JVC GR-X5 Mini DV Digital Camcorder
I can't get the tape to eject. PLEASE WAIT is the message that is displayed on the screen
Please let me know more about the message, go down further below if there is a numeric code like "03" or "02" etc. Because If it is because of condensation tape can be ejected. Please wait message also appear when you inserted a high capacity SD Card and you are switching from REC to Play and every time you switch cam on, the bigger capacity the longer you will wait, i suggest remove it when not needed. Please give as more details if none of the mention above solves your problem.
Jan 25, 2010 | JVC GR-D290 Mini DV Digital Camcorder
Condensation, operation paused
Try running a cleaning tape through the JVC 2 or 3 times and also wiping all around the tape compartment with a long cotton bud soaked with isopropyl alcohol. It cured my problem in Singapore.
Oct 30, 2009 | JVC GR-DX97 Mini DV Digital Camcorder
I have a Digital JVC Camcorder with mini DV with failure code...
That come on because of a humid condition or moisture on the head drum of the camcorder. This is usually cause by going fro a hot enviroment to a cold enviroment. This prevents tape damage or destruction as the tape will stick to the head as it spins. You can open the cassette compartment and use a hair dryer on a low setting for a couple of minutes to get rid of the moisture or just leav the cassette door open for about an hour or until the warning clears.
Aug 19, 2009 | JVC GR-D50 Mini DV Digital Camcorder
I CAN'T OPERATE MY CAMERA
Condensation is usually a result of a change in temperature of your camcorder. Like taking it from a warm house and shooting outside in a chilled environment. Or taking the camcorder that was in the car in a cold environment into a warm house. Condesation will make the tape stick to the revolving video head and the camcorder has sensors that know this could be a very bad thing for both the camcarder and your tape. So the camcorder shuts down. The tape also needs to be at the same temperature as the camcorder or temperature differences will create condensation between the tape and the video head.
Eject the tape. Shut off the camcorder and leave it in a room temperature place for a day. Then give it a try.
Dec 12, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Please wait -Condensation operation Paused
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Feb 02, 2008 | JVC GR-D31EK Mini DV Digital Camcorder
Gr-dx97 - condensation, operation paused message on screen
Dec 31, 2007 | JVC GR-DX97 Mini DV Digital Camcorder
Help me please....
try removing the battery and take a clean soft cloth and gently wipe surface.
Jun 21, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
JVC GR-D22U Camcorder Logo
173 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
