Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Freezer works fine but the fridge won't get cold
Freezer is steady at zero and has not changed but the fridge will not get cold. I've vacumed out the coils as well as checked the duct at the back all seems fine but still won't get cold.
  • 237 Answers
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Posted on Feb 27, 2007
Top part of freezer will not keep food frozen.
Posted on Jan 28, 2009
Try this: Ice maker has rake that scoops ice out of mold and into bin.  Bag from hot dog buns gets caught in rake, causing overload breaker to trip, same breaker that controls evaporator fan that blows cold air into fridge from freezer.  Remove bag, breaker resets, fan starts.  GE fridge.
Posted on Oct 20, 2007
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
Bottom freezer left open overnight. Freezer does not work anymore. Top fridge does not getting cold as it should be.
Your fridge gets it's cold air from the freezer. If the freezer is not working then the fridge won't get cold.
May 26, 2011 | Refrigerators
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Fridge not cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jul 19, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
The temperature controls for the refrigerator are not responding. The freezer controls respond just fine. My fridge is set to 34 and I need to get it back to 37 but it won't change the numbers.
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 14, 2009 | Sub-Zero 650 / O Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
2,478 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
