Question about Garden
Ryobi lawn hornet wont start....continually
How do i remove the clutch assembly so i can remove the plastic cover
Hi Tamcoff - If its the same model as mine (and you can't always rely on the Parts Cattledog!!):
- to remove the bell housing; twist off the spring and using a T20 torx screwdriver unscrew the retaining screw in the centre of the housing (normal RH thread)
- place a large screwdriver in the slots of the cover to jam the impeller and using a copper drift (or similar) and hammer, tap sharply the in one of the clutch recesses (one of mine hasd 'OUT' embossed in it) unscrew the clutch from the drive shaft (normal RH thread)
Cheers,
Bob
Posted on Dec 08, 2008
Need to remove flywheel ryobi RLH1100 mark2
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Nov 04, 2011 | Ryobi 15" Electric Factory Reconditioned...
I have a ryobi lawn hornet mk.111 and I need the cover that goes over the carburetter is it still available?
http://shop.ebay.com/i.html?_nkw=ryobi+cover+&_cqr=true&_nkwusc=roybi+cover&_rdc=1
Apr 03, 2011 | Ryobi Garden
Replace the starter pull cord for a ryobi lawn hornet
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed
Jan 07, 2011 | Ryobi 15" Electric Factory Reconditioned...
How do I rmove the clutch rotor from the shaft so I can access the pulley rotor assembly -does it screw of and if so is it a RH threaad? It is a Ryobi Weed Hornet 77 31cc
I always describe this solution in detail, and am going to include pictures this time. Here are online instructions with pictures, followed by my directions.
http://www.ereplacementparts.com/article/1771/How_to_Remove_a_Trimmer_Clutch.html
Here are my instructions to aid you.
(Yes, the Torx screw inside the clutch drum is a right-handed thread)
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers
Nov 26, 2010 | Ryobi Garden
How do I remove the clutch rotor assembly on a ryobi 720r?
I have the same model, I inserted a large screwdriver on the inside to stop the rotor assembly from spinning, then I used a pipe wrench (but channel lock pliers would probably work better) and then w/o much effort, I easily turned the wrench counter clockwise to loosen.
May 01, 2010 | Ryobi Garden
Ryobi Electric Lawn Hornet Model RLT800QF. Need
I went to www.ryobipower.co.uk, I was ynable to find a lawn hornet on the website. But you may have better luck because in the states we do not have lawn hornets.
Good Day Mate
Dec 14, 2009 | Garden
How to remove the 'governor?' so that I can remove the plastic cover and replace the cord pull on Ryobi strimmer RPT2543C
What you are calling the "governor" is accutally the clutch drum. The is a screw in the center that needs to come out, then you will need to remove the clutch with a small punch and small hammer, by unscrewing it. Then you should be able to get to the recoil assembly.
Hope that helps.
Good day, mate.
Oct 23, 2009 | Garden
How do you take off the clutch off a RYOBI lawn hornet mk3
You have to hold the engine from turning, somehow. If you get it held firmly, then you have to give the clutch a rap with something to loosen it. I use a piece of hardwood and a hammer. Make sure it is being driven counterclockwise. All you have to do is get it loose, once you do, you can remove it with your hands.How to keep the engine from turning? Some suggest using a bolt threaded the same as the spark plug, turn it in past the top of the cylinder. Now turn the engine over easy until the piston touches the bolt. Now is when to rap the clutch with the wood/hammer. Good luck...Lee
Oct 08, 2009 | Ryobi Garden
Primer button Ryobi lawn hornet
Vacuum created by piston operation after closing the choke pulls fuel into carburetor port into engine. In much the same way as the primer bulb provides fuel for the port. These type engines usually take a few more pulls before they will start. And if there are any leaks in carb. system will be very hard to start.
Apr 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
218 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
