Question about HP iPAQ 111 Classic Pocket PC
Programs won't upload to my ipaq 111 classic ppc
I just got a new ipaq 111 classic running Mobile 6 classic. I have tried to add/sync programs to it using WMDC but nothing seems to get there, Out of the five or six different programs I have tried, only MyPersonalDiet works (I think it was the first one I tried as well). Any ideas?
In case this matters, I also am running Vista 64bit.
I have an iPAQ 111, I can't sync anything with my laptop (Vista Business), I already downloaded the Windows Mobile Device Manager, but... I just can't connect both hardwares. Please, help me to fix this main problem. Thanks.
Posted on May 21, 2009
I did not know that I needed to do a soft reboot on the PCC. Once that happened, everything loaded at once. I don't know where it came from, but it all loaded.
Posted on Dec 12, 2008
IPAQ HX4700 won't sync with desk top
Hello, Please try the following steps. They could help with your problem. First open this link to hp's download page for your PDA. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?&lang=en&cc=us&pnameOID=420535&taskId=135&prodTypeId=215348&prodSeriesId=420534&lang=en&cc=us Then select your pda's operating system (windows mobile 2003se or windows mobile 5). then from the following page select the ROM update and download it. Try to master reset the pda (you may find informations about this in the user manual). After you reset the device, don't tap anything on the screen (don't follow the welcome wizard or anything it asks you to do). Just connect the usb cable to the computer. Activesync may try to connect to the pda, may fail or things like this. It doesn't matter what does it do as long as it does something. Now open the ROM file you downloaded and press "next" untill the process begins. If the setup asks you to reset the device or things similar, don't do it. Just continue with the setup and "tell" the program you already done that. Make sure your battery is charged before doing this. Also make sure the pda and the computer are left alone these 10 minutes (that's how long it takes to do the ROM update). If the ROM update fail, please post a comment and give me the error message and code. We will take it from there. Also please inform me what version of windows are you using and eventually an email adress for me to send various service programs required for the next stage (if the rom update fails to work). Good luck, Bogdan
Sep 25, 2007 | HP iPAQ HX4700 Pocket PC
Ipaq 111 hard reset
Soft reset Perform a soft reset
A soft reset stops all running applications, but does not erase any programs or saved data.
NOTE: Be sure to close all running applications before performing a soft reset.
To perform a soft reset:
1. Locate the recessed Reset button on the HP iPAQ.
2. Use the stylus to lightly press the Reset button.
Hard reset
To perform a hard reset and return the HP iPAQ to factory settings:
Press Win + OK + Record together.
While doing that, press reset button and hold for 3-4 seconds.
Release reset.
Release buttons.
NOTE: Do not release the buttons until CLEAN REBOOT appears on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | HP iPAQ 111 Classic Pocket PC
Wont sync with windows 7
If you haven't already done so, try to uninstall and reinstall WMDC on your PC. Reset both your PC and PDA, and try again.
Just my 2 cents... Carlos
Apr 16, 2010 | HP iPAQ 111 Classic Pocket PC
Microsoft Money etc. Sync Problem with iPAQ hx2495b
UR SYSTEM GOT THE VIRUS SO NEWLY INSTALLED UR WINDOWS AND INSTALLED LATEST ANITIVIRUS WITH UPDATE.
Oct 05, 2008 | HP iPAQ HX2490 Pocket PC
Ipaq 4100 problem syncronizing with outlook on new laptop
you are now using outlook 2003 , probably cache , this means all the email is on your laptop. when you sync it will sync all the email (thousands). initialise your ppc (back to factory default). set up the sync via usb cable. then sync via bluetooth . then you are fully sync. now setup an auto backup of your email data (daily). if after some time , you have sync problem again , initialise the ppc, restore from backup and you are back to sync (last full backup). try this , you will never need to do it all again.
Regards
David Ng
Sep 23, 2008 | HP iPAQ H4150 Pocket PC
Windows Mobile Device Center (Vista SP1 32bit) Can't sync with my IPAQ HX2490b
For the Samsung i760, disable "advanced network functionality" in the "USB to PC" setting by uncheckmarking it. Then Vista and WMDC will detect the i760 properly...
Apr 01, 2008 | HP iPAQ HX2490 Pocket PC
IPAQ file store problem
You're not alone! Virtually every ipaq rx3715 gets this problem at one time or another. Unfortunately, it is a massive memory issue. Be prepared to potentially lose all of your data, including programs. My suggestion would be to back up your ipaq before you do this. I do not know if the backup retains the memory error, but what I would do is back it up, perform the fix, and then restore the data back onto the ipaq. If your file store problem is fixed, there you go! If the problem comes back upon restoring the pocket pc, then unfortunately you will lose all data and programs in order to fix the memory, and that will be a personal choice. For most of us, the ipaq simply freezes up upon entry into the file store, so consider yourself lucky that they simply do not delete.
Here is the step-by-step process of how to fix your problem.
1. Download GER and ENG ROMs (latest) from HP's support site
2. Unpack both
3. Cancel the automatic flash procedure.
4. Locate the EnterBootLoader.exe file in the folder of the unpacked GER update
5. Copy it to PPC
6. Run it from the PPC
7. Run the ROMUpdateUtility.exe file from the desktop to start flash procedure.
Then you have a German-language PPC
8. Locate the EnterBootLoader.exe file in the folder of the unpacked ENG update
9. Repeat steps 5-7 for the English update
You're done
Remember, you're not alone! We all had the same problem.
Jan 18, 2008 | HP iPAQ RX3715 Pocket PC
Pocket pc 3850
Set it up with what? Do you mean sync with your computer? Are you using USB or Bluetooth?
Best thing to do.
1. Unplug your USB connection from PPC -> Computer
2. Uninstall Activesync if you have it installed
3. Restart your computer
4. Re-install activesync
5. Restart your PPC
6. When asked to connect the PPC connect it via USB
Jan 06, 2008 | Compaq iPAQ H3850 Pocket PC
HP iPAQ 4150 battles Vista -- HELP
The Microsoft Windows Mobile Device Center requires that the first sync be made via the USB sync cable. After the h4150 is plugged into the Vista machine, the WMDC opens and prompts you through setting up a partnership. Then you can set the h4150 to sync via Bluetooth.
ActiveSync works fine with Vista. Ignore that other guys post.
Nov 29, 2007 | HP iPAQ H4150 Pocket PC
HP iPAQ 111 Classic Pocket PC Logo
283 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
