Question about Samsung DVD-R135
No Picture I received this DVD recorder/HD upconverter for Christmas. It has worked fine until today. When I put a dvd in, the sound comes on but there is no picture. It cannot be the connections because I have it connected to the tv via hdmi & to the directv box via av cables. The picture will not show up through either connection.
    Problem Solver:
  • 4 Answers
Sounds like the digital video controller went out. you can test this on this unit by using the coax out and connecting to your tv, it seems to have its own video card looking inside the unit, however it is possible it is controlled centrally thorugh the main card in that case you will confirm by it not working and still only gettting sound through the coax.
Posted on Jun 21, 2008
SOURCE:
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
This dvd recorder worked PERFECTLY when I had digatal cable. As soon as I up graded to HD with a HD box from comcast, I cannot get the recorder to record anything. I hooked it up the same way as I did with...
The HD box from your cable company only sends High Definition Video signal which DVD does not support. Your DVD recorder "CANNOT RECORD THIS PICTURE" because it can not process (see) the High Definition (HD) Signal.
To record from an HD reviver you would need a HD recorder (Blu-ray) very expensive The standard practice for recording from a HD cable receiver id to use an DVR here is a link to one for about $100 some models will have a standard video output you could connect your dvd recorder to.
http://www.google.com/products/catalog?q=HD+Dvr&oe=utf-8&client=firefox-a&hl=en&cid=15241578777457062393&ei=puGPTNuoFIm4iwSJ2s1h&sa=title&ved=0CBcQ8wIwATgA#p
Sep 14, 2010 | Sony RDR-GX330
Green picture on dvd upconverter LG?
the red cable on the auxillary cables had come unplugged from the back of the dvd player. plugged it back in and picture is awesome!!!!
Mar 27, 2009 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
No picture on tv
This unit upconverts all video inputs to component output, so connect all your devices to your denon audio and video inputs and component video out of the denon to the tv component in and all should work fine
Feb 21, 2009 | Denon AVR-886 Receiver
I have an old Zenith Digital Surround System the Receivver is a Model Z763B with a DVD Player/Recorder connected. When I play a DVD or VHS the sound can be heard through the TV and the Sound System,...
I have the same A/V receiver and in my setup there is an audio output (red and white able) coming from DVD player directly into Zenith Z763B. The video from DVD Player goes to TV input (yellow cable).
There might be alternatives to the setup mentioned above but I like to watch movie in a surround sound, rather than output from TV.
Jan 07, 2009 | Audio Players & Recorders
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Playing HD Video
This machine won't play HD-DVD. What it Will do is to play standard discs and upconvert them to your HDMI format...accordianman
Jan 06, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Dec 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung DVD-R135 Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
