Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Cant find old furnace filter for model # fguj080abn
The furnace model is irrelevant. The important question is usually the dimensions of the opening for the filters. The most common sizes are 16"x25"x1", 20"x25"x1", 16x25x5, etcetera. There are exceptions such as specialty filters like electronic ones. I suggest using inexpensive pleated filters but you could just use filters that you cut to fit instead. Have a helpful gasfitter assist you if necessary.
Posted on Dec 26, 2009
Lime scale build up and slime in bottom of filter tray
If your water is suddenly evaporating into limescale, your local water company may have switched to a different water source, or your water softener device is out of salt. The limescale can be easily cleaned with vinegar and a sponge, but this will keep occuring unless you use water that doesn't contain disolved calcium. Try getting an RO water filter and use that water.
Feb 16, 2014 | Aprilaire 550 Humidifier
My lennox furnace works just fine except that 25% of the time the fan keeps running when it shouldn't and blows cold air
You are using too restrictive of an air filter. If the codes you are getting off the lights says anything about a high limit this is the cause of your blower running all the time. Use a less restrictive filter or have your contractor install a media filter in the system. if you reset the furnace and it does not stop running the blower you have a stuck limit switch and may have to get another or call a service tech to reset it or replace.
Oct 27, 2013 | Honeywell Power Humidifier: Furnace...
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
Water flow ok to side valve. no waer flow to top of 1042-l unit. valve extremely hot. is there an expert service maitenance available in montreal
Replacing this solinoid valve is not hard to do. This is something the homeowner can accomplished with small hand tools. Turn power off at the furnace and the inlet water off at the saddle valve.Remove the water line at the valve and the connector exiting the valve. Remove the two screws and the valve is off the unit. Armed with the make and model number of the unit goggle the manufacture with the model number and order your replacement valve on-line. Install the new valve opposite of which the old valve was removed or per manufactures instructions that may come with the new valve you orderd.
Jan 23, 2011 | General Filters 1042-LH Humidifier
Our aprilaire humidifier is only 4 years old and it does not seem to be working. We have static in the house and when I did test mode it never drained water like it was supposed to. Any ideas what I can do...
Hope this helps, check and see if humidistat is set to 35% humidity and that bypass damper on humidifier is in the open position or winter position.(humidistat is usually located on cold air return duct near furnace). Next, replace humidifier media pad, remember to replace media pad (filter) annually, you also may want to clean any lime deposit out of humidifier housing with a solution of warm water and white vinegar before installing your new media filter.Remember to turn power off at side of furnace when cleaning humidifier and replacing media. Before installing new media turn power back on to furnace, set humidistat to the on position, turn furnace thermostat above room temp., and inspect humidifier to see if water is running from top,(you may want to have a bucket under humidifier when checking for water), if you see water running, turn power back off to furnace, properly install new media filter, reconnect humidifier cover & set humidistat to 35%. If you do not see water present, check water supply valve to humidifier and make sure its turned on. If water supply valve is open, then check water supply tubing for blockage.And the last things to check is to make sure all registers through out your home are open and not blocked by any objects, also make sure furnace filter is cleaned, if none of this works refer to installation manual to see if humidifier was sized and installed properly, Good luck.
Mar 03, 2010 | Aprilaire 600 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
The Aprilaire is leaking around the casing attached to furnace
How old is the filter? Filters should be replaced every year. If its a new filter check to make sure the little hose is inside the hole at the tom of the filter.
Jan 18, 2009 | Humidifiers
Cleaning a furnace humidifier steel filter?
Most water panels are generally replaced once a year on flow through humidifiers.
Dec 20, 2008 | Honeywell Power Humidifier: Furnace...
IFC on Trane furnace
If the manufacture says it is the IFC then you should have the IFC checked by the company who installed it if it is under warranty still
Jun 06, 2008 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
103 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
