The Icon for my Zip250 Drive disappeared from My Computer, and I cannot reinstall it from the original Version 1.0 insstallation disc. I cannot access my 250 files.
  • 4 more comments
  • suntrail Dec 08, 2008
    All my USB & power connections are in place & 250 drive lights up, indicating that some activity is going on.
    The solution sent could not be executed, because tahere is no hardware tab under properties. Jack Ward
    I found the disk drive listed, but nothing happens when I double click it.
  • suntrail Dec 11, 2008
    I solved the problem on my own. Thanks.
    Top Expert:
  • Computers & ... Master
  • 77,499 Answers
Go to the device manager, remove the zip drive from the storage device menu, the do a cold restart, that is where the power is disconnected for a 5 minute time frame, restart and plug the zip in, the system should recognize it and reload the software.
Posted on Dec 08, 2008
    Sergeant:
    Novelist:
  • 192 Answers
Ok, when you right-click My Computer, and select properties you should get a small window titled System Properties. In the window you should be looking at General. This shows you the basic information of your system. There are seven tabs you can choose from, but the second one along from General (the one you're already looking at) is called Hardware. This is the one you want. Then select Device Manager. The hardware option has to be there, as it is part of Windows.
Follow what electronick has suggested, but if that doesn't work, you can add your zip drive manually.
Manually adding Zip drive:
Open Control Panel. You want to be in Classic View, if you're not, you can select it from the left at the top. Then you want to select Add Hardware. This will be along the top line. This will start the wizard.
Follow the instructions it gives you, it will search for the new hardware. If it doesn't find it, it will ask you if the hardware is already connected. Click yes. This will start the Troubleshooter.
Also download the most current Service Pack from Microsoft (if you haven't already), as they may have added extra support for the drive.
    Genius:
  • 1,239 Answers
HI,WELCOME TO FIXYA
This problem is experienced after following performance suggestions found in third-party documentation, on web sites, or in newsgroups. These suggestions instruct users to remove all folders from the desktop of Handheld PC Pro device in order to speed screen-repaint rates. Applying these same steps on a Handheld PC 2000 device causes all desktop icons to disappear.
Microsoft has documented this issue (in Q289674): http://support.microsoft.com/support/kb/...
To restore the My Handheld PC and Recycle Bin icons on the device, follow these steps:
1. Tap Start, tap Programs, and then tap Windows Explorer.
2. Tap the My Documents folder, tap Send To on the File menu, and then tap Desktop as Shortcut.
3. "Soft" reset the MobilePro. The My Handheld PC and icons should return to the desktop.
Note that you must have at least one folder or shortcut on the desktop in addition to the My Handheld PC and  or else the problem will recur.
    Sergeant:
  • 399 Answers
First, if you have another machine to test with, try connecting the Zip drive to that machine to verify that the drive and its installed disk are functional. If that works, try connecting it with a new disk (if you have one), and see if you can format that disk with the Disk Utility application (found in the Utilities folder in your Applications folder. If this works, then the disk should appear on the desktop; at least in a Finder window. If this works, then your problem would seem to be a problem with the disk that you currently have in your Zip drive.
----------------------------------- click the link for more help http://discussions.apple.com/thread.jspa?messageID=8494450
  • 4,806 Answers
Click on start menu and then programes, the Zip250 should be in the list, if not click on "computer" and then disk "C" click on program files and look for Zip250, you should be able to find the icon there. post back if you can't find it
regards
  • Lee Hodgson
    Lee Hodgson Dec 08, 2008
    perform a system restore, >>>>>>> start menu, all programs, accessories, system tools, and then system restore, take the computer back to a time before you installed the updated version.
    kind regards
    Genius:
  • 1,142 Answers
Uninstall the software and restart the system, unplug the device after uninstalling the drive then replug it and download the latest driver from this link and reinstall the driver
http://www.driverfiles.net/Removable-Drives/Iomega/zip-100-250-usb-scsi/download/page,sh,19163,877,23,.html
  • 505 Answers
You can try reinstalling the driver
on windows xp
right click my computer, go to properties
click the hardware tab, click device manager button
the zip250 should be under the disk drives
expand it out to find the drive - double click it
in here, under the driver tag you can uninstall it
re-install to hopefully fix
  • thielectronick
    thielectronick Dec 09, 2008
    if doubleclicking doesn't bring it up, then right click and go to properties. this should accomplish the same task.
Tip
Reset your Apple's Original Admin Password.
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
    Choose a language, click the arrow button to continue,
  2. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
    Select your Mac OS X hard disk volume.
  3. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  4. Enter a new password.
  5. Click Save.
  6. Click the red button in the upper left corner to quit the application.
  7. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  8. Click Restart.
After following these steps, you'll want to also follow the steps in this article.
Mac OS X v10.6: Resetting the original administrator account password on a Mac that has no optical drive
These steps require a second computer that has an optical drive.
Note: If the second computer is a Mac, make sure Mac OS X v10.5.3 or later is installed. If the second computer is a PC, make sure the DVD or CD Sharing Update 1.0 for Windows is installed.
  1. Open "Remote Install Mac OS X" from the Utilities folder.
  2. Follow the onscreen instructions.
on Feb 10, 2010 | Computers & Internet
How do i fix an f3-f200-0002 error on my lap tap???
Step 1:
A recovery disc is a CD provided by a computer manufacturer that will assist the owner in reinstalling Windows and system device drivers in the event of a hard drive failure. If your original Toshiba recovery disc has been misplaced or damaged, it may be difficult to get a replacement disc except through the mail from Toshiba Product Support. There is a free download work around available, however, if waiting for delivery by mail is not convenient.
Find a Windows Setup Disk Find an original setup disk for the version of Windows you need. If your COA is for Windows Vista Home, you must find a Windows Vista Home version setup disc. You can borrow a disc from a friend, or buy a used disc online. There is no source for a free download of Windows. Even though you use a friend's setup disc, you will use your unique COA keycode to activate the Windows installation. b> Reinstall Windows b> Reinstall Windows using an authentic setup disc and your keycode. In some cases, Windows will locate and load drivers for your Toshiba laptop automatically, or at least provide substitute drivers until you can Install the correct drivers. b> Reinstall the Drivers b> Use the flash drive or disk you burned to restore the device drivers to your Toshiba. It is a good idea to start with the Ethernet or wireless adapter so you can connect to the Internet to find more suitable drivers online and activate your copy of Windows. Work through all the driver install packages to restore drivers for Ethernet, wireless, BIOS, sound cards, video cards, optical drives, touchpad functions, keyboard controls and other devices. b> Plan For The Future b> Make an attempt to replace your recovery disc through Toshiba. Otherwise, consider creating a perfect copy or "ghost" copy of your restored operating system and device drivers for future use. Use an external hard drive for this creation, not a partition on your current hard drive.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/repairStatusLogin.jsp notebook repair http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp Toshiba support
Feb 24, 2013 | Toshiba Satellite Computers & Internet
The original 250gb HD failed. I replaced it with a WD 320gb HD. I have tried to load the Lenovo restore DVD and a new, never used, Windows 7 DVD. Both drives take EXCEEDINGLY long to load (the Windows 7...
Welcome to FixYa!
It depends on how you used the recovery disc that you have, reinstalling operating system will not take 23 hours just like what you said so there's a possibility that you're having problem with the Operating System on your computer. Unfortunately, Lenovo will not provide a product key for the Operating System since the an OEM version. What you can do is reinstall the Operating System using the One Key Recovery Sofware or the Recovery Disc that came with the computer. Follow these steps for you to be able to reinstall the Operating System using the One Key Recovery.
1. Turn off the computer.
2. Press the little button near the power button, it usually do have a drawing of an icon that looks like a horse shoe or a headset.
3. There will be a window that will appear which do have three option, One Key Antivirus, One Key Recovery and System Setup. Choose One key Recovery.
4. There will be another window that will appear which do have two option, Restore from initial backup and Restore from user backup,Choose Restore from initial back up
5. It will asked you if you want to continue, Just click on OK or YES.
6. Once done, Reboot the computer.
For Recovery Disc,
1. Insert the disc inside the drive.
2. Turn off the computer then turn it back on and keep on tapping F12
3. There will a window that will appear which do have three options, HDD,ODD/DVD/CD, and NAT, choose ODD/DVD/CD
4. It will asked you to press any key immediately, you will need to press any key immediately so that it will boot from ODD.
5. It will asked you to choose a partition, choose Disc 0 partition 1
6. Reboot computer once done.
I hope this information will be helpful. Thank you for using FixYa...
May 16, 2011 | Lenovo IdeaPad Y510 Notebook
Apple G3 starting problem
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Note
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
Feb 13, 2010 | Apple MacBook Mac Notebook
How can I find the admin password on my mac. I had a new hard drive put in my pc. I want to change some of the admin settings but I need the password. How can I find it or change it without knowing the...
  5. Click Save.
  8. Click Restart.
  9. After following these steps, you'll want to also follow the steps in this article.
Feb 10, 2010 | Apple MacBook PC Notebook
How do i completely wipe out everything on my toshiba laptop?
Go to thepiratebay.org and search for torrent of the windows version you want and download it by most popular and nice torrent downloader Utorrent .if it worls please mark it as helpful thanks
Nov 01, 2009 | Computers & Internet
Windows XP freezes up when trying to reinstall on my Dell
You need to copy the restore partitions to a cd for back up.the wipe the drive using drivescrubber.also have a start up disc for back up.wiping the drive from back to front should keep the basic files for dos.its easy and there is a free version.
Sep 20, 2009 | Dell Dimension 3000® Pentium® 4...
I purchased a Compaq Presario (SR1810NX) in April 2006. Word software was factory installed. A few months ago, the word icon disappeared. I tried to update it on the Microsoft website and my entire...
You most likly have to format the hard drive, and completely clean out the hard drive and re-partiotion, and then install the recovery disc.
Aug 01, 2008 | Computers & Internet
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
