Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Hooked up a hdmi/dvi cable
I just got high def hooked up i used a hdmi/dvi cable on my hitichi 65 inch projection tv now i have a blue tint to my picture (like its missing a color) my tv has a connector that is like a computer connection
    Genius:
  • 1,199 Answers
Try using the red- blue- green high def connections
Posted on Dec 08, 2008
Is there any alternative to using hdmi input to the tv
Yes, there are several ways to connect to the tv. HDMI is the (NEWER) way to connect the console. The reason being, is because HDMI carries both video and audio. The standard way to connect is by using the provided (RCA) cords that came with the system. They connect by splitting the video(yellow) and audio(white=left red=right) Almost all tv's out now have either HDMI or the audio/video inputs, and are typically cable ready.(little threaded plug in the back that your cable box hooks into) You can purchase a cable ready adapter from game stop or even use the one from an existing PS2 or PS1. They all use the same adapter from the system. The only difference is, if you don't connect with HDMI then you are NOT going to have high def available. It will be in standard def all the time. The final way to connect is a bit difficult. It requires a bit of knowledge in what your doing. HDMI to a HDMI adapter to DVI-I or DVI-D monitor. Some tv's come equiped with a DVI-D input so it can double as a monitor for a computer. This way WILL give you HIGH DEF and arguably the best picture you will ever get because you can set the frame rate (frpm) your self. Hope this info is useful. Good luck. ^^
Nov 29, 2013 | Sony Video Game Consoles & Games
Wd65738 blue screen
blue screen means no video signal, if the source is on hdmi ensure the cable is rca or in simple audio video jacks which u will have to connect in the dvi input of the tv reason is hdmi means high definition interface and transmits by hdcp like the data of an internet meaning its digital platform which the tv can only process thru the dvi inputs or component y,p,b
Jul 17, 2013 | Televison & Video
Where does the HDMI cable plug into for a Blue ray player?
i have the same tv. there is only a dvi input with separate audio inputs.you will need a dvi to hdmi adaptor to connect for hi def.hdmi is video and audio while dvi is only video.you still get the picture quality,but have to run audio rca cables also.
Jan 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a High Definition ready TV, I'm trying to hook up an Epson High def box to it ,I have it all programed in but there is no High def picture. I went and asked the cable company and they said the High...
HERE is what you are looking for I presume.......DVI to Component correct??? if this is not it, pls be more specific in regards to the connection on the converter box.....'
GOOD LUCK AND PLS RESPOND TO THIS POST!!!!!!
Feb 24, 2010 | Zenith R50W46 50" Rear Projection...
I have a Playstation 3/blu ray player and I don't know how to get hi def video on a samsung hln467w
Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Hook up a lg blueray player to mitsubishi medallion 65"
Yes, there is an adapter which will take the hdmi output of the blue-ray and convert it to dvi. You will also need to connect the blue-ray audio out (rca jacks) since the hdmi is both audio and video (digital) and the dvi is video only.
Jan 04, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Switching from HD to Standard screen gets a pinkish/purplish tint in SD only
It is the cable box. Using the HDMI or DVI output on cable boxes is a bad proposition; for some reason the cable box makers have not figured out how to make the HDMI/DVI output work consistently, something that rarely happens with satellite boxes. Use the component output. You will probably not be able to see a difference in picture quality and your problem will disappear. If you liked this solution, please be sure to rate it. Thanks!
Oct 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Jan 23, 2008 | Onkyo TX-SR674S 7.1 Channel Up-Converting...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
163 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
