Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
Replace bad HD with new 5oogb
My 200Gb HD crashed in my HP/COMPACK computer.
When I try to reinstall windows XP Pro, I can't format the
new hard drive higher than 137gb.
    President:
  • 623 Answers
This is a rather technical problem with MS Windows and the 48bit Logical Block Addressing scheme.
You can read more details here: http://support.microsoft.com/kb/303013
Short solution: You have to install Service Pack 1 (or better SP2) in order to get past this problem.
I assume that you had this disk in you computer before, so the BIOS should be able to handle this as well.
Posted on Dec 16, 2008
I have a old gateway pc and I would like to install a Hard Drive from a Dell pc into it. Can it be done?
Swapping the hard drive from the Dell into the Gateway will not work because the Dell hard drive has been installed with Dell specific drivers and configurations.
When you install the Dell hard drive into the Gateway you need to wipe the hard drive and install a fresh copy Windows XP onto this hard drive and the Gateway device drivers etc.
Oct 29, 2012 | Computers & Internet
I have a HP G7-250CA in which the Hard disk crashed during a bios update. I have put in a new hard drive and now want to do a fresh install of Windows XP as I do not have the recovery disks. I keep...
Hi
can you please explain to us how the hard drive crashed during a bios update ?
or how do you know that the hard drive crashed during bios update
many thanks
And did you try to reinstall windows while original hard drive was still in the laptop
did you press the F11 key as soon as you pressed the power on key
Mar 07, 2011 | HP G70-250us Notebook
EMachines ET1810-01 trying to install xp pro on clean hd, cmos does not show hard drive and xp says there is no hd. it is connected. how do i get it to find the hd?
You need to format your hard drive. Set your boot device to cdrom in your bios. Boot using xp cd.DO a reinstall of windows and it should give you the option to format or delete partitions on your hard drive. if that doesnt work try putting the hard drive in another computer to see if it works. Or you can buy a hard drive enclosure that allows you to use your hard drive as an external device.
Jun 11, 2010 | eMachines (ET181001) (A1803181 ON) PC...
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
My acer aspire t180 crashed a few months ago and i did not have a windows disk to reinstall it so i used the disk that i got with my dell pc(this seemed to work) but now i have bought a windows xp disk i...
Is the disk you have xp pro? If not, just do the xp home or whatever is on the disk. You may have to format your hard drive to clear it to accept the windows. Get plenty of advise before you do anything permanent like formating your hard drive. Get any factory disks that you can that will have your bios on them.
May 04, 2009 | Microsoft Windows XP Professional for PC
Dell 2350 Won't boot up without cd
Check the jumper on the back of your drive. Chances are that the jumper is either on "slave" or "cable select". Change the jumper to master, and try rebooting.
Mar 11, 2009 | Dell Dimension 2350 PC Desktop
I downloaded a copy of windows vista and it expired,im trying to reinstall my hp windows xp recovery cd and its asking me for a password,cant remember if i ever did set up a password for this pc.how can...
At what point is it asking for a password? Has the computer formatted the hard drive yet? It sounds like you might be going in to Recovery Console instead of installing a fresh copy of Windows.
What you want to do is press Enter at the first screen, agree to the license, and then format your hard drive. After that, it will go through the installation without asking for a password. Remember - you'll lose all your data when you format.
Jan 23, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
New 200GB HD on my LG P1 Express Dual
i have p1 express dual, i have put windows 7 ,2 gb ram , and upgrade HD to 250 7200rpm, i only have to run a cd so i update the bios. my email is m4rios@hotmail.com it took me many hours of searching to find it, i ll send it to anybody i dont believe that even lg company has that bios, is from ''phoenix''
Mar 17, 2008 | HP Pavilion dv6000z Notebook
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
127 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
