Hello, My fan outside is froze & my heat is not coming out like it's suppose to. Can you tell me how to get the ice off the fan?
  • 85 Answers
If were talking ice, melt it with a hair dryer, or torch. If it's the whole unit is frozen, your defrost is not working, and you will need to replace the defrost board, or the thermostat for the defrost mechanism. If the unit's fan froze meaning it won't work only the compressor, then the fan died, and you'll need to replace the motor.
Posted on Dec 08, 2008
Ice builds up on top of evaporator and fan blade hits.I checked evaporator and there was no ice build up below this area. I thought it might be a defrost problem but coil is totally iced. I thawed it out...
This sounds like no defrost is happening. Frost is supposed to accumulate and then be heated and water runs off, routinely.
Check defrost timer and heating coil.
Mar 18, 2015 | Whirlpool WRF560SEY 30" French Door...
Ruud achiever 10 froze up but the fan works but not getting cool air flow through house. what is causing this?
The most common things that will cause a system to freeze up are:
1. Dirty air filters
2. Dirty evaporator coil
3. Indoor fan motor not running
4. Blocked/restricted return air flow
5. Low on refrigerant charge ( most common)
I would start with the filters. When the system is froze up, turn off the "cool" and just have the fan set to on. Make sure there is no more ice anywhere, turn the system back on and check your air flow throughout the house. If it feels normal, then filters, return, and fan should be good. The outside unit will have warm to hot air coming out of the fan if the charge is good enough, but that's not a perfect way to check, you will need gauges and a temp reader with knowledge of super-heat and sub-cooling to check the charge the right way. Hope this helps and good luck!
Jun 22, 2011 | Ruud Matching Split Air Conditioner
Hello, I have a Ruud Silhouette II Plus 2 gas furnace installed in my garage. This is the first time that I've had a gas furnace (living on my own) so I am unsure of how it actually works. One thing...
If you have gas furnace, the outside unit will not come on unless you have dual fuel/ gas and heat pump. If you can look at wires in thermostat, if you have no wires going to O or B then you don't have heat pump. Normal tstat wiring for gas furnace and air conditioner. R,W,G,Y and maybe C.
Jan 24, 2011 | Heating & Cooling
I have A York Affinity 1800 AC/Heat Pump and a Honeywell Control.TH 8000 Series.My outside unit froze up and was making a noise. I read my Honeywell instructions and found out I should set the unit to...
The DEFROST cycle is not engaging out side.EMG(electric only) will heat untill the outside unit melts and is looked at.The noise is the fan blade hitting the ice.
Jan 10, 2011 | Honeywell Heating & Cooling
My Goodman gsh103301ab. The fan in the outside unit will not come on. The heat is still coming out the the vents but, just don't think that sounds right. Is this suppose to happen?
If it's in cool mode, the outside fan definitely should run to remove the heat. If it's heat mode the outside fan will start only when pressure build up. If it's problem with condenser fan definitely the breaker or fuse will be blown when the amphs increased.
Dec 08, 2010 | Goodman CKL36AR36 Air Conditioner
Jan 12, 2010 - My air handler fan (american Standard #TWE065E13FBO) works during a/c operation but not during heating operation. Checked continunity through the the thermo sw and throught the heating coils...
You need to check if the air handler fan running.Suppose if you donot see it then, check to see if the fan on the outside unit is running. If the fan on the outside unit is not running either, check to make sure that the breakers for the furnace/air handler and the air conditioner are on. Also if the breaker is not tripped, then the problem may be your thermostat, the furnace/air handler control board, or the wires between the furnace/air handler and the thermostat.
Let us know if you need further assistance.
Thanks for contacting Fixya.com
Jan 12, 2010 | Heating & Cooling
BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
Jun 23, 2009 | 2001 BMW 5 Series
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
Heat pump fan does not run when house heat is on
The outside fan should be running except when the Heatpump goes in to defrost mode. Then the fan stops with the compressor running and it switches the reversing valve to heat up the outdoor coil. That should last about 5 min and you may see steam come off of the outdoor coil. That's normal.
Is the compressor running? It's possible that it's stuck in defrost or the fan simply died. I hope this helps.
Feb 19, 2009 | Sharp CV-P09FX Air Conditioner
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
