Question about RCA F35673MB 35" TV
The picture is drawn in from the sides
The picture is sharp, convergence is good, color is good. the picture is slightly compressed in the center. The black is curved ) (, about 4 inches top and bottom and about 6 inches in center. The chasis is an RCA CTC187CL3 , THE MODEL IS F32672SB.
  • metromedic34 Dec 09, 2008
    it is a pincushion problem, it is a bad solder joint, hit the base of the tv about three times with my fist and the picture went back to normal for about 2 seconds, then back to the hour glass look..
  • 105 Answers
This problem we cal vertical fault..cause by capasitor is not in good condition at vertical area or loose solder at the vertical ic
Posted on Dec 08, 2008
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
My Sharp 61 inch projection HD tv has a blue band of shadow that dips below the image. Looks like 3D without the glasses.
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B misalignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Sharp 61RWP4H 61" Rear Projection...
Left and right sides, seeing triples in three colors,but the center is fine?
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have picture colors shadows or 3D picture look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 08, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Image is harp in center and lburred on both sides.
Readjust ur tube back to the original position.Ur convergence is dead,Must know to solders?Replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 06, 2010 | Televison & Video
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
RCA D52W23 breakdown in projection focus
First check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v If cp150 is puffed up on top it is bad , then there is a fuse FL231 on right side of flyback transfomer it will be the middle fuse if open you will lose convergence on picture .
Dec 30, 2008 | RCA D61W20 61" Rear Projection Television
The picture is distorted. It appears as the picture is being drawn to the center of the screen.
This is a convergence problem. This can be either bad solder connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These are large black ICs attached to a heatsink.These should be marked STKxxx.
Keep me posted.
Dan
Sep 30, 2008 | Sony KP-65WS510 65" Rear Projection...
Sharp TV model 27H-S60 convergence
HI ,USE A PATTERN GENERATAR DOT OR LINES TYPE AND USE THE CONVERGANCE RINGS BEHIND THE YOKE OF THE SET ,THERE ARE THERE RINGS FOR EACH COLOUR RED GREEN AND RED .SLIGHTLY MOVE THE RINGS AND U CAN SE EIN THE PATTREN THE COCLOUS WHICH IS FRINGES EACH BY EACH U ADJUST ALL THERE RINGS FOR PERFECTION , FIRST LET THE SET BE SWITCHED ON FOR 1 HOUR AND THEN DO THE ADJUSTMENT. THANSKS
May 22, 2008 | Sharp 27H-S60 TV
Hitachi projection tv model 3 51gwx208
Do you mean that at the top of the picture, the red color has shifted downward, bowed towards the center? If that is what you see, one color suddenly bows toward the center on any side of the picture, then it means that one of your convergence IC's has burned out and needs to be replaced. It is a good idea to go ahead and replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's and realigned the convergence circuits in a projection TV then allow a qualified tech to handle it for you.
Aug 05, 2007 | Hitachi 51GWX20B 51" Rear Projection...
Televison & Video Logo
156 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
