Have a denon avr 588 surround reciever that does not stay on the on/stand by button has a red light that is flashing it powers on for about 3 seconds then shuts off and then the red light starts flahing
  • stephlizeric Dec 09, 2008
    there is nothing connected to it
  • stephlizeric Dec 20, 2008
    I DISCONNETED ALL WIRES AND CABLES STILL DOES THE SAME
    Genius:
  • 1,199 Answers
This could be two wires touching on the back connections. one wire touching another ...just one will do this! look close and causing a short (its shutting off is a safety feature so the unit does not overheat)
Posted on Dec 08, 2008
DENON AVR 1507 short?
unplug it, let it set for about 15 min., plug it back in and see what happens. Hopefully it will recycle itself. If that fails, with your theater remote, you can pull up it's functions screen on your TV, and probably return it to factory default settings. That would be a last resort for me before seeking professional help. Good luck. . .
Jul 27, 2017 | Denon AVR-1507 Receiver
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Denon AVR-588 Sound Delay
FIRST, IF YOUR USING HDMI CONNECTIONS IN THE DENON HDMI SETUP YOU HAVE TO TURN THE AUDIO DELAY ADJ. ON
SECOND, THE DELAY TIME ADJ, FOR OTHER SOURCES IS LOCATED ON PG 27 IN THE MANUAL, HERE IS THE LINK TO DENON SITE WITH MANUAL
http://www.ca.denon.com/AVR-588-OM-E_102.pdf
Jul 12, 2008 | Denon AVR588 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Not working
When you indicate system stopped work, I assume you mean the receiver is dead or malfunctioning. I need more info for more advice
Apr 24, 2008 | Denon AVR588 Receiver
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
