Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printhead How do I remove old printhead and install a new one?
  • aaalexco Dec 10, 2008
    Recieved replacemtn printhead from kodak but no instructions on how to do the replacemnt: only go to "www.kodak.com/go/printheadsupport" which got me here.
    Some directions. What do I do now ?
  • kcamp62950 Dec 23, 2008
    will not print
Remove both ink catridges..under the top edge of the prtinthead cartridge basket,on the left side ,you will feel a small square button..Push up a little with your finger,and tilt the basket forward from the top..It pops right out.Install the new printhead bottom first,then tilt it in until you feel it lock in to place..
Posted on Dec 22, 2008
Oh my gosh. It just took a second once I felt that little releast button. THANKS!!!
Posted on Dec 28, 2008
How so I remove the old prinhead and install a new one
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. Scroll to the Printhead menu icon (icon on the lower right of the front panel display) and press Enter.
  4. Scroll to Replace Printheads and press Enter.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. When instructed, open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts in all carriage slots and on all printheads (instructions below).
  10. Allow the contacts to dry.
  11. install the new printheads and close the carriage cover.
  12. Close the top cover.
  13. Turn the printer on and attempt to verify functionality.
Apr 18, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have new printhead.
First, go to Canon i9900 Support
If the Support & Service tab is not selected, click on it.
In the search box type reseating printhead and click Search.
One of the results will be "How do I reseat/remove the printhead?"
Click it. A step by step (with animation) will be shown. Just install the new printhead when it calls to reseat the printhead.
Make sure you do the printhead alignment after installing. if you are unsure about how to do this, go back to the support page above and search for align printhead. There will be step by step instructions for this too.
Thanks for using Fixya.
Dec 03, 2009 | Canon i9900 InkJet Photo Printer
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
New Printer - Issue with installing printhead
first of all.. make sure that you remove the packing material from the cart or print heads and put them in properly.
then also if it it gives the same probem then try it with the old print heads.. if it doesnt gives any eror with the old ones then replace the new ones..
new ones are bad..
return them to store
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
How do I remove and replace printhead esp3
cartriges Take them out, push the button on the top left of ph and install new one, pushing on the thumb picture. then install cartriges.
Jun 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have the new printhead for my 5500 All In One. Your instructions tell me to go to kodak.com/go/pintheadsupport. When I do this, it tell me I can find instructions and pictures explaining this by choosing...
remove the ink. on the left side of the printhead (the old one) there should be a button you can depress near the top. push it and the printhead should come off. put the new printhead on and push it where there is the sticker until it clicks into place. remember! take off all the things on the new printhead. I think it's orange?
Jan 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
open the access door at the top of the printer
Remove the ink cartridges
Put your finger in the upper left corner of the printhead ( inside)
you will feel a small latch rigth there push it upward
the printhead will loose and you may now remove the printhead
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Remove printhead
please don't repeat post as i said before, remove both ink cartridges. on the top of the printhead, near the left there is a button. push it and the old one should come out. to put in the new one take all the protectors off and push it in where the old one used to be. push on the thumbprint until it clicks and reinstall the cartridges.
Jan 18, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Replacing printhead in Kodak 5300 All in One Printer
on this website:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
You can find illustrated instructions on how to remove the old printhead, as well as on how to put the new printhead back in place.
You can easily go to that website by going to:
and selecting the second option "installing new printhead".
Nov 05, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
I did not see the bulls eye, as there was not one there when we bought the printer;
But just get a flashlight, there will be a little and I do mean little button at the very to of the tray. you almost have to put your head into the printer to see it. Push that button up firmly but not try not to be to rough with it, lets face it this is a sensitive printer.
Pushing this button up will release the tray, and you will be able to pull it out.
Oct 29, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
157 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
