Question about Pioneer DEH-P3300 CD Player
Help! Wife about to kill me!
The unit was working fine in my truck. I removed it and installed it in my car. Now it does nothing at all. I have the proper power to the proper connections and have verified such at the junction on the back of the cabinet. Any help would be appreciated. Jake
    Problem Solver:
  • 9 Answers
Without knowing what car it is you might want to check to see if you need the harness to have the factory Head unit still hooked in to recieve EMERGENCY Alerts, usually this is on the GM models i am not sure of others. Second check the harness with a test light and also the radio fuse either under the hood or dashboard -=or both in some situations=-
Posted on Feb 21, 2007
Radio no power
not knowing what your working on I'm going to guess did you change out stock radio with aftermarket some cars need a radio reset code3.
Mar 17, 2017 | Cars & Trucks
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
2005 dodge caravan changed cam crank and egr but still jerking a little during acceration whats left no codes help
Did you check the MAS (mass airflow sensor), check it, clean it, I hope you wife won't kill you.
Mar 16, 2013 | 2005 Dodge Caravan
I'm getting a 5100 "check printer" error on my
Reseat (remove / reinstall) the ink cartridges if an error appears. Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Passenger side door lock does not work on my 1994 pqrk ave buick. It makes a small effort but thats all. Others all work fine
Remove door panel and inspect lock area.Make sure nothing is interfering with lock and door handle rods.Lubricate lock mechanism with light lubricant.if lock still does not work, install new actuator assembly.It will be easier to remove lock assembly to properly install new actuator.Be sure to note connecting rods to lock for proper reassembly.It saves time to mark them with different color paint.It is also a good idea to always perform voltage and current test on any electrical circuit before replacing any components.
Nov 22, 2010 | 1994 Buick Park Avenue
Everything was working fine, then one day I switch...
Try to check your CPU unit it maybe have a power when you turn it on. Or just check their power suppy at the back when it works. If you check that all and it works normal just check inside your computer and try to see the Power LED (Light Emiting Diode) of the motherboard if have a light. Because if it is have a light your motherboard is good and if it is no light in the Power LED of the motherboard that was damage. But if your motherboard does not have installed Power LED try to check the CPU Fan it maybe works properly it because the CPU Fan was conncected in the motherboard if did not works the motherboard is also damage and need to replace. But if the CPU Fan was working properly, try to hold the CPU Heatsink if it is very hot the damage is your micro processor.
May 20, 2010 | Intel D945GCNL Motherboard
Installed Boss bv2600 au media player in a 1996 camry have power to the unit and the monitor works fine with other units, the power button has a red light on but pushing it does nothing will not accept dvd...
sounds like a bad unit try to return it if not it sounds like you need to properly rewire it and i believe ground it so you can use it because i think it has a safety feature so you cant use it while driving. Try it see what happens
Aug 30, 2009 | Car Audio & Video
Pioneer DEH-P3300 CD Player Logo
79 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
