Question about Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television
Image outside of bounds of television.
I have a Mitsubishi WS-65311 projection TV. I've noticed that many sources seem to extend well outside the boundaries of the screen- basically, all sides, top, bottom are chopped off, and the rest is blown up to fill the screen. This is true across several sources that I can tell (antenna, VCR, DVD, component, composite, etc). Getting tired of the tops of everyone's heads being chopped off! Anything I can do?
  • nwalton Dec 08, 2008
    Correction: It's a WS-65411
    Sorry, I should have specified: this is irrespective of the format. Good thought, but I have tried changing formats- this happens in 16x9, full, stretched, etc. The last inch or two of the image is just not there. It acts as if it's just zooming in ~110% all the time- enough to chop off portions of score bars on sports, things like that. I've tested this with sources that have their own zoom functions (DVD player that allows zoom and panning), and I can see edges that way that are not visible under normal conditions.
    Sergeant:
  • 261 Answers
There should be a format button on the remote you can hit. This should cycle thru all the "formats" that the set can do. 16x9, 4x3, wide mode, Full mode, stretched mode, etc.. Let me know if that helps you.. Happy holidays... Jay
Posted on Dec 08, 2008
  • Jay Henderson
    Jay Henderson Dec 09, 2008
    Was this a new set out of the box? It sound like to me that it could be setup wrong either from the factory or someone has been tweeking around in there. One other possibility is that the High Voltage could be low. Usually around 30,000 to 35,000vdc. Does the picture ever jump or zoom in and out momentarily? If it does, I have seen on a rare occasion carbon build up on one of the main H.V. Leads coming out of the H.V. Block. Usually this is a big Black box that all the red wires run into and all it really does is distribute the High Voltage to all the 3 CRT's equally. You can usually push in and twist and then look inside with a flash light and see if everything looks good and shiny. If it does then i am wrong again, But we will keep on tryin... Good Luck and keep me posted... Talk to you later... Jay
The tvs front buttons are locked and the tv is off how do we reset it
While the tv is on, press and hold the MENU button for 6 seconds and that will unlock the front panel
Jul 10, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi 65311 rear projection- no red
tube, pull the front grill off and gently tap on the neck of the red crt see if it momentarily comes back.
Sep 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
There seems to be no green on my 65 in tv
reheat al the pin of the ic chroma section as well as the crt circuit check also the lot solder part and resloder it.
Sep 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi 1080 series, ws-65311 model
Same problem.. Checked the fuses but they're fine no reset switch to be found.
Sep 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
65 inch Mitsubishi replacement screen? (WS-65311)
I think I can help you out if you still need that screen, I have a new screen, both fresnel and lenticular lens in a frame for a ws-65411. contact me at jgrisz@comcast.net
May 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
