Question about Mr. Coffee FTXSS23GTF Coffee Maker
Brew time Our nearly new Mr. Coffee has slowed down in it's brew time. It takes nearly 40 minutes to brew a half of a pot. Why :(
    Scholar:
  • 135 Answers
If you have hard water, minerals may have built up in the unit, slowing down the flow. You should be able to find some sort of mineral-dissolving treatment for it at your local grocery or hardware store. Make sure to run a few pots of plain water when you are done, to get any residue out!
Posted on Feb 21, 2007
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
My Mr. Coffee is taking over an hour to brew a pot of coffee
Run a half a pot of vinegar through it then 2 or 3 pots of water. It's from lime and calcium deposits.
Nov 05, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
All I need is the manual to my Mr.Coffee Pot how to set the timer to Mr. Coffee GBX23.
First set the clock on the brewer with the unit plugged in. Press and hold the Hour and Minute buttons until the current time is set. Next press the Delay Brew button while using the Hour and Minute buttons to reach the time you want the coffee to begin brewing.
Set up the coffee maker with ground coffee or beans and sufficient water in the reservoir then follow the directions below.
For brewing with fresh ground beans, press and hold the Delay Brew button until it flashes then press Select once. The Grind and Brew light should come on and the Delay Brew light should become steady.
For ground coffee, press and hold the Delay Brew button and then press Select twice. The Brew Only light and the Delay Brew light should both be on and steady.
Most Mr. Coffee product manuals are here: http://www.mrcoffee.com/InstructionManuals.aspx . The direct link to the GBX23 manual is http://www.mrcoffee.com/Manuals/MANUALS/GBX23_43_50118420.PDF .
I hope this helps.
Aug 20, 2011 | Mr. Coffee GBX23
My Mr Coffee Coffee Maker, 12-Cup Programmable, Black - SKX23 just stopped working yesterday. There was no overflow or mess to explain why it won't brew anymore. The power light does come on when 'ON' is...
When heating elements fail they do not brew sad to say before driving that far I would call or email the company about it . lots of coffee makers are not repairable since heating elements are spot welded to the water pot .
Nov 12, 2017 | Mr. Coffee 072179228578 12 Cup Coffee...
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a Mr. Coffee model JHX33 coffee maker, and have lost the owners manual I need cleaning instructions. Can you possibly help me?\r\n Thanks Eddie Thatcher
mcdevito75 here, I too have a Mr. Coffee, coffee maker 4 cup. The instuctions shold be just about the same for both our Mr. Coffee mavhines, ------ With a new or clean filter in the machine fill the pot 3/4 way full of White Vinegaar the pour that into the resovior, place thepot back in place on the machine and start the machine up, let the vinegar cycle thru, when done the vinegar is now in the pot, empty the pot back into the resovoir, and cycle again, this time 1/2 way thru the cycle or pot half full stop the cycle for 30 mins. this will keep the vinegar in the machine and claen all the little ports. After 30 mins, complete the cycle. repaet this 2 more times. Then repaet once the machine is cool but this time use plain water, repaeat plain water cycle 3--4 times to clean out all the vinegar, Mr. Coofee needs claening when you notice coffee brewing has slowed down or maCHINE STEAMS TOO MUCH DURING BREWING CYCLE.
Jun 19, 2010 | Juicers
When I put 12 cups of water in the container, only 8 cups brew. Also, it takes 30-40 min. I ran vinegar through it twice and am getting the same results.
the coils are super heating, and condensation of your water is vanishing faster than it's brewing. It sounds like your coffee pot is ready to go to mr coffee heaven
Aug 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee starts to brew and then stops
You could turn it off, unplug it ( is it plugged into a GFI outlet?) empty it of water and clean every part that you can get off it thoroughly. then dry it carefully and then plugging it back in and just try running water through it with a filter in place. This is just a simple reset. (Even coffee pots are computerized now!)If this does not change anything,
I would clean this pot, put it back in the box and take it back to the store where I purchased it, along with the receipt or credit card receipt. I would not take "no" for an answer. You should not be having these problems after ten uses. Let me know how it works out.
Thank You Your rating is always appreciated.
Aug 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee FTXSS23GTF Coffee Maker Logo
994 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
