Question about Sony KP-53V85 53" Rear Projection Television
Picture doesnt look as clear as before.
I think i need to replace lamps i had the tv since 2001 any advice will be helpful thanks........
  • 505 Answers
If the colors are mis-aligned or letters are out of focus, you may need to repair. For mis-alignment you can push the flash-focus button on the front to autoconverge the colors. Replacing the CRTs would cost a fortune. If the picture has just degraded in brightness and clarity, you cold clean it out. You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Posted on Dec 08, 2008
I just replaced the lamp on my Samsung HLS5087 and now the TV won't power up. The 3 LEDs are lighting which indicates that the lamp needs to be replaced. I put the old lamp back in to make sure there is...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem,,,,
Dec 06, 2010 | Televison & Video
I want to change the lamp. Any advice, directions, words of wisdom ? Thanks Stuart
One word followed by the reasons
DON'T!
Many who think this is just like changing a light globe end up with numerous halo and ring problems on the screen mucking up the picture.
1) There is a matching sequence with the globe
2) it has to be retuned across the screen so thatthere are no shadow areas, rings and halos. So i't's like a focus that is finely set using an instrument to ensure optimum.
3) the lamp hours are reset inside the unit as well as on the screen.
There are 50 peiple currently who changed their own lamps and now have more problems than they need, most times we can't help them because we don;t know what they fiddled with to begin with.
Please rate my help+_++++Thanks for using FIXYA
May 23, 2010 | Zenith D60WLCD Television
Hi I have a hitachi LCD projection TV my lanp and
yes you need a lamp about as sure as anyone can be without looking take lamp out see if its brke inside or has any whit smoke spots in it
Feb 06, 2010 | Hitachi 50VF820 Projection TV
I have a sony kf50xbr800. This TV was purchased new in 2001. After 5 1/2 years the lamp had to get replace. TV been working good till now. While watching tv it will go to stand by mode, after about 2-min's...
The thought is that it needs to be either cleaned out. Dust build up in it's air intake filter or you probably need another new lamp. Usually when these set's shut themselves down is because they are overheating or they can't maintain the voltage to keep the lamp lit.
Blessings,
A/V Media Tech Guy
Nov 25, 2009 | Televison & Video
Replaced lamp still not working. no picture no sound. standby,timer and lamp lights blinking. what's your advice?
Two possibilities, make sure lamp cover is fixed properly in its position and screws are tight or ballast supply need to be replaced.
Hope this info will help you.
Nov 21, 2009 | Samsung DLP HL-P5663W 56" TV
I have a Sony Wega KDF-50E2000 that doesn't turn on. The green light blinks for a minute or so and then the red "timed out" light blinks continuously. Yesterday, the TV turned itself off with the green...
Did you replaced lamp in TV recently?
I think TV needs new lamp as existing is either broken or dead.
Lamp replacement procedure would be mentioned in user manual or let me know to provide you more info.
Thanks.
Sep 16, 2009 | Sony KDF-50E2000 50" HDTV
Need help replacing fog lamp in 2001 bmw 330i
Hi, the fog lamp should have a cover surounding it. this will just pull off then you will see a 8mm screw bolt, remove this and the fog lamp should then be able to be removed.
Mar 14, 2009 | 2001 BMW 330
Samsung tv turns of by itself
The lamp can cause this but also a faulty lamp door switch will cause the same thing
Make shure that when you replace the lamp
the lamp door switch is in the up position before the door is put back on
Jan 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Tv dimming
It is probably time to replace the lamp. Be sure to buy an original Sony lamp, as the aftermarket replacement lamps are known to have issues. If you liked this answer be sure to rate it. Thanks!
Jul 16, 2008 | Sony KDS-60A2020 60" HDTV
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KP-53V85 53" Rear Projection Television Logo
261 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
