Question about Fujitsu Siemens LifeBook N6200 Notebook
Why won't my card reader in my Fijitsu n6200 notebook read my 4gb
Sandisk Ultra II card ?
  • Anonymous Mar 26, 2014
    will this notebook read sdhc cards?
Suddenly can't access the images on the card
Run some anti-virus software on it.
My advice to try quick heal anti virus.
Nov 20, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
When I inserted the new memory card (SanDisk Ultra II, 4GB) into my Canon PowerShot A620, it tells me "Memory Card Error". This is a brand new card. What do I do? It had been working just fine with a...
Some cameras cannot handle over 2GB memory cards. If it works fine with 2GB card - stick to that. If some other A620 you know operates with 4GB card, take yours to repairs.
Oct 24, 2009 | Canon PowerShot A620 Digital Camera
Formatting an CF 4GB sandisk ultra II....How to do
The camera uses FAT16 so it won't be able to use cards bigger than 2GB. IF you can format it, you will only have 2GB space available.
Formatting the card: Press Menu/OK, select Setup, Select Format, press OK untill it's done.
Oct 11, 2009 | Fuji FinePix S7000 Digital Camera
PC does not recognize SanDisk Ultra II 8GB memory card.
install the usb drivers 3.0 it wi;l solve u r problem...........
Sep 27, 2009 | SanDisk 1GB microSD Memory Card
Camera reads, computer doesn't
That is odd. Try the recovery software that comes with the sandisk cards and see if you are able to get them after that.
Do you format your cards each time in the camera before shooting?
Jul 10, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Memory card locked
On your SD card, there is a small tab near the top (similar to floppy a disks), just switch that the other way it should fix that lock error.
Jun 11, 2009 | SanDisk Ultra II 2GB Secure Digital Memory...
SanDisk Ultra 11 CompactFlash Card 4Gb says "Card not Initalized"
You may need to format the card. There should be a Format command in the Setup menu. To be more specific, one would need to know which model of Finepix camera you refer to.
Apr 03, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
San disk ultra II won't show up on computer
You'll have to go to Sandisk.com to verify this for your specific model, but... the problem is that some firmware versions won't recognize over a 2GB card. There may be a firmware update available. Find your product on the site using search, and then look for software updates. Don't hesitate to call techsupport (866-726-3475).... usually NOT a long wait, they speak clearly and they're polite.
Feb 04, 2009 | SanDisk Ultra II 8GB Secure Digital High...
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Fujitsu Siemens LifeBook N6200 Notebook Logo
238 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
