Question about Dishwashers
Frigidaire washing machine
Dishes come out more dirty after the cycle, dishes are wet, soap sometimes doesn't dissolve.
  • mietusjm Dec 11, 2008
    I melted a plastic spatula on the heating element inside the dishwasher a month ago. Did this likely cause the problem and is it fixable? Do I have to replace the heating element thing? Is this the same or different than the "coil?"
    Top Expert:
  • Dishwashers Master
  • 77,544 Answers
The plastic spoon would have caused this problem, remove the sprayer head from the bottom of the washer, see if the screen is plugged with melted plastic, if it is remove it and try the wash cycle again, also check the discharge hose into the garbage disposal and see if it pumps water, if none of the above works u will have to replace the water pump, don't panic they are cheap, have done a couple for this very issue of melted plastic.
Posted on Dec 11, 2008
    Master:
  • 479 Answers
You may have used detergent not designed for automatic dishwashers. You may be using too much detergent/tablets. Or you may be using liquid detergent. Some rinse agents and mechanically softened water will also makes suds. Putting 2 tablespoons of oil into the sudsy water at the bottom of the dishwasher will help break up the suds. Sprinkle ordinary table salt liberally across the suds to disperse them. Add a large quantity of ice cubes from your freezer to the tub. This causes the water temp to lower, thus degrading some more of the suds. Try to drain the unit as much as possible, soaking up any residual water or suds with a dry towel. Let the unit fill again, and repeat the salt and ice if necessary.
 also use a commercial spa or water bed de-foamer, which is found at Home Depot or any pool supply store. This works as a surfactant to break down the bubbles almost instantly. (Only squirt a few drops in and run the unit)
  • 734 Answers
Please tell me about the model number
Thanks.
  • futureloginn
    futureloginn Dec 11, 2008
    Poor cleaning is generally caused by not having enough water in the tub, which is usually the fault of the water inlet valve. You mentioned cleaning the filters... which filters? Did you remove the valve and clean its screen/filter? If that screen gets clogged with debris (and they do) it'll choke off the water supply to the tub.
Dishes come out feeling gritty. Using Finish doesn't help
If you open the door immediately after the dishes are washed, and before the "dry" cycle, is the water hot enough to have "steam" coming out of the machine?
You should be able to feel the heat.
If not, perhaps the water is not getting hot enough to dissolve the dishwashing powder.
Could you try using a liquid soap once and see what happens?
Be blessed.
Feb 17, 2013 | LG Dishwashers
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
The detergent packet doesn't dissolve. The dishwasher seems to go through the cycles ... the dishes are wet. However I find the detergent packet in the bottom of the dishwasher.
Hello- Water flow, temperature, and pressure inside determine whether this little packet will dissolve.  Sump blockages or pump /motor weakness both effect amount water spraying inside. Some of these packets don't dissolve in time to enter wash water. Start by using powder or gel again. If it still leaves soap residue, other pump/motor issues exist. Let me know if this info helps- have more if needed. Thanks- ED
Mar 09, 2010 | Frigidaire Dishwashers
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Dishes come ot just like I put them in
Check that both spray bars are turning. They can both be easily removed.
Once removed, make sure they are not clogged with stuff to prevent them from turning.
I assume you can hear water spraying around inside when it's washing, and that the dishes do get wet, and water does get hot.
Soap dispenser requires water hitting on it to open.
Jan 28, 2009 | Maytag 24 in. MDB9750AW Dishwasher
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Water is not circulating. machine runs full cycle but when opened, soap is in a mushy lump, not dispersed or dissolve, and dishes are still soiled
When was the last time you cleaned you drain filter? That should be done routinely .. If that's clogged then the the sediment from other cycles just gets redistributed on your dishes.. You might also check the washing arm that spins for debris or clogs.. Try cycling it without any dishes a few times to see if all the water drains out after a cycle.. That will help you identify if its a drain problem or if the system needs other service.. Hope that helps !
Aug 18, 2008 | Frigidaire Dishwashers
Open Questions:
Dishwashers Logo
Top Dishwashers Experts
