Washing Machines Logo
Wayne Conover Posted on Jul 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking washing machine
Model NAV5805AWW Periodic leaking during spin cycle from bottom of machine. Hoses appear dry, both water feeds and drain hose. Has happened with items like blankets but not limited to heavy items in load.
Level 3:
  • Amana Master 17,130 Answers
  • Posted on Jul 05, 2012
Amana Master
Level 3:
Answers
17130
Questions
0
Helped
3631848
Points
52372
It is so common that the drain leaks in many ways andis the most problematic fault in a washing machine. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that water hasleaked then as the drain hose pump/valve and fittings are located on theunderside of the machine it is important that you look for possible leaks here.In some cases the drain hose would be clogged at the drain end to outlet of thehouse and so there will be back flushing resulting in overflow to the outside.Also the drain pump/valve can be clogged or the drain hose clamps can be looseon the grip which can all cause the leak to occur. Removing and cleaning thedrain pump/valve, tightening of the hose is also very important. Also water canleak if there are gaps on the front door gaskets and must be checked but thiswill happen only during the cycle and not on the drain cycle end.Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html Check for tips on the link below to identify parts andremoval:http://www.espares.co.uk/advice/washing-machines/a/7
4 Related Answers
Jimster
James Greene
  • 240 Answers
  • Posted on Sep 09, 2007
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Anonymous
  • 156 Answers
  • Posted on Mar 03, 2008
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Dec 26, 2008
SOURCE: Whirlpool washing machine leaking in spin cycle
replace pump
Andriod Man
Android Man
  • 278 Answers
  • Posted on Feb 09, 2011
SOURCE: I have a kenmore top
most likely is the water pump. you need to remove the cabinet to get to it and is at the bottom center. a white looking part. the shaft seal is bad.
My GE washer leaks water during spin cycle only, seemingly from bottom of valve(?) where water hoses hook up, hoses look to be in good shape, only a year or so old.
If it is leaking at where the drain hose comes out of the wash machine, make sure the plastic spider clamp is seated securely in the groove on the drain hose. If that's not it, then, yes, you'll need to open up your washer to gain access to the inside of it. I don't know which model GE wash machine you have, but most of the GE top loaders can be opened by following the instructions in this youtube video:
Amana tandem 7300
What does it mean when a washer leaks from the bottom?
The pump will have an outlet or drain hose, an inlet from the tub and may have a circulating hose outlet as well. If you have water leaking from the washer during a wash or drain cycle, check the area of the drain pump. Look for signs of a loose hose clamp or a leaking hose connected to the pump first. Washer Repair Diagnostic Leaking Water Amana Whirlpool NFW7300WW
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
I have a kenmore top load washing machine model 110.92597200 that started leaking during the rinse cycle. The drain pipe isn't leaking and the water line hoses are just a few months old. They were both...
My ecosmart GWL11 Fisher and Paykel washing machine is leaking water from the bottom, I think during the spin cycle, but am not sure--there is a puddle of water when I come out to put clothes in dryer. ...
Double check your drain hose is both attached and that there are no splits in the hose. I have found that even the smallest split/hole leaks huge amounts of water. If the hose has come off you will obviously need to reattach it, if it is split i found it best to replace rather than repair the hose.
Washer leaks when on spin cycle
drain is not working properly so that only spin is not starting
1helpful
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
1helpful
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
