Question about HP DeskJet 920c InkJet Printer
The quality of printing is poor.
I replaced my black and white cartridge and color cartridges. However, the printer appears as though it needs cleaning as the background is smudged and appears "dirty." Would you know how to clean the printer?
Thank You
  • 475 Answers
Try a little water on a q tip and rub gently to remove any excess ink
Posted on Dec 08, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
2600n faded print on both left and right side.(word doc, no images) not using color black print only.
Is the cartridge an original HP or an inexpensive compatible? The black cartridge could be out of toner. Not a common defect for the Q6000A cartridge though. If it is a poor quality compatible the defect may be the result of a misaligned internal component. Either way replacing the black cartridge should resolve the issue.
Jan 18, 2010 | HP Color LaserJet 2600n Printer
Need to print with black cartirdge only.
just try to print a black and white, you can do that when you print a document. There is a window that will pop up about to print, click on properties just beside the ame of your printer and go to paper/quality bar menu there you should see a choices between color and black&white. Just choose black & white and try printing.
Jun 22, 2009 | HP LaserJet 2840 Printer
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
The color cartridge runs out very quickly even though I rarely use it. I make sure to print in black and white, and I manually choose the option "Use Black Cartridge only" but the color cartridge runs out...
Printer manufacturers design their printers to print some color mixed in with the black when you are only printing black. That is why your color cartridge is running out when you only print black and why it prints "weird colors" when the color cartridge is empty. Printer manufacturers sell the printers at a loss and make up the profit on the cartridges.
Feb 20, 2009 | HP D4360 DeskJet Printer InkJet
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
Full black ink cartridge - but says there is no black ink
To run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
  1. Ensure the printer is powered on.
  2. Lift the scanner unit.
  3. Open the cartridge latches and remove the cartridges from the carrier
  4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
Cleaning the Contacts
  1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
  2. Using a clean dry cloth, wipe the contacts in the direction, so that no dust or other contaminants are visible.
  3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
  4. Replace the cartridges in the carrier and close the scanner unit.
  5. Print the document again.
  6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Verify the Ink Cartridges Are Installed in the Proper Slot
  1. Remove the ink cartridges from the printer.
  2. Read the label on the side of both cartridges to identify which is color and which is black.
  3. Install the black cartridge in the slot on the left and the color cartridge in the slot on the right
  4. Close the ink cartridge lids and make sure they lock in place.
I hope it helps!!!
Nov 18, 2008 | Dell 924 All-in-One InkJet Printer
Printer doesn't print well
Hav you replaced with original cartridges or 3rd party/refilled ones? This is a common problem when using generic/refilled cartridges. Let me know that first..
When you say poor quality, do you mean faded printouts, or broken print? Kindly explain in detail, so I can assist you further.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP DeskJet 920c InkJet Printer Logo
93 people viewed this question
Ben Johnson
