Question about Ricoh Aficio 2018D All-In-One Laser Printer
I am having trouble scanning a document on the Ricoh Aficio 2018D, I also cannot locate the user manual, can you please advise how to scan on this machine?
  • HUSSAIN4508 Mar 02, 2009
    I'm facing the same problem. I already install all the driver . My printer working very well.But when i want to scan after open my adobe acrobat 6.0 ,error code 12320 cannot locate scanner appear
    .what should i do .
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at Ricoh.com, under Downloads, but this will not help very much with the scanner config.
Sorry:(
Posted on Feb 14, 2009
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Place the originals in the ADF, press the Scanner button,
select a destination email address/quick dial buttons or input email address manually by pressing Manual under the display and then press the Start button.
Posted on Jan 10, 2009
When pages come out of the copier the image is printed crooked. The paper comes out straight, so feed is correct. Image is just crooked? Why?
Does this happen when you using the document feeder?? Try placing the original document on the big glass see what happens might be you document feeder needs to be adjusted or the original document is hitting a obstruction in the path as it is being scanned. Does it print OK? Vise copy?
Jan 25, 2016 | Ricoh Aficio 2018D All-In-One Laser...
I used to be able to scan a lot of documents and then just last week I couldn't scan any document using the Ricoh Aficio Type 2018. The message "Sending has failed. Press Job Information key to check the...
It is a problem with the network connection, if you are using scan router recheck the configuration settings in case of scan to email check connection with smtp server, port no. ssl on or off and do the connection test, check mail server authentication, rest assured it is not a problem with the machine or GW controller.
Feb 18, 2015 | Ricoh Aficio 2018D All-In-One Laser...
How do you scan with the Ricoh Aficio 1515mf. I don't have instruction manual.
scanner button, put the document and choose the user. In the end you click on the green button to start
Jan 11, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Why am I getting a black line across the pages when I scan? I did change the cartridge and it's not happening on all documents. Thank you.
you have got a dirt or marking on 2 places 1.mark on the ARDF unit exposer glass
2. on the scanner unit mirrors
check and clean both 1,2
Nov 03, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh aficio 2018d error sc302 can someone please advise what the problem is
The manual says that this is a chage roller leak.
Means the the high voltage is arching to ground or drum somewhere....usually pinhole in chage roller
Feb 17, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018D - previously used a scan router software to scan to file on Windows server. Now being told Windows server 2008 is not compatible. We are using scan to email but very cumbersome. Is there...
No, all the newer machines have imbedded scanning. The scanrouter software was an old product and only supported through 2k3 server. I would setup an old PC with the scanrouter and whatever platform you were running before and use it just for scanning. You can install it as a service so it will run on its own.
Feb 02, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Dont know how to configure scanner on Ricoh Africo 2018d. It is set up as a network printer atm
There are a few ways, such as configuring "SMB", "Scan to "Email" and/or installing "Scanrouter", but they are too involved to explain here.
The other is the "Network Twain Scanner" which, once installed, you can use a program such as "photoshop" , or many other photo editing softwares to scan. Simply open the program, click "file", "Import" and you should see the scanner as an option, make your settings, and go.
You can get the software here. Just select your operating system. It will need to be installed on each PC:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x2015_18/x2015_18en.htm
Mar 06, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
930 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
