Question about Zanussi TC7114W Electric Dryer
My zannusi dryer is will not dry clothes on hot setting
Zanussi condenser dryer tc7103w dryer will not dry clothes on hot cycle, removed heater element and checked it out, found no problem with the element, any idea what else it could be? dryer is just 2years old
  • David Seddon
    David Seddon Apr 04, 2007
    thermost replaced dryer ok
    door thermostat is accessed by removing the rear cover, the drum then has to be removed, thermostat located in plastic surround at top of machine behind the door
  • Anonymous Sep 04, 2008
    Zanussi TCS603LT
Thermostat in door part no 1258406014 should do the job colin
Posted on Mar 06, 2007
Hotpoint WDUD9640 washer dryer clothes coming out wet and hot
check the exhaust tube externally and internally for excess lint build-up on the sides. You may not have the vent obstructed, but you may have the venting restricted. Clean out lint if there is excess. It may need a good scraping/ brushing to help your machine breathe. Just an extra thought.
Mar 11, 2018 | Hotpoint Dryers
It doesnt seem to dry very well or takes a really long time
Zannusi Dryer TDS383W element gets Hot (glows)then cuts out after few seconds then if I wait for couple minutes and reset the clock to any set time the element glows hot again until inbuilt thermostats 'click' again cutting out the element,this process is continuous with or without the lid and ducting in place.
Feb 14, 2014 | Zanussi TD4112W Electric Dryer
I have a problem with the performance of the dryer on my Zanussi WD1272. the clothes get hot but at the end of the cycle are still wet. No problems with washing. Please help
Could be condenser or water solonoid valve fact that s hot says heater ok.fact that its wet perhaps not cooling down to water and pumping out fully, also check that the filter is clean....
Nov 26, 2010 | Zanussi WDA1055W Front Load Washer / Dryer
Zanussin tc7103w not drying clothes
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 17, 2009 | Zanussi TC7114W Electric Dryer
I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
ZANUSSI TC7103W
There is a thermostat inside the machine just inside and top, put your head in and look up. Took my whole machine apart before finding the wire which led to it!! It should be Normally Closed (NC) and cuts the power to the heating element when too hot or broken! Hope this helps.
Bolts
Mar 28, 2007 | Zanussi TC7114W Electric Dryer
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Zanussi TC7114W Electric Dryer Logo
675 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
jimorris77
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
