Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
My Kogi 17 inch monitor illuminates for 2 seconds and then the light goes out. The monitor is still on but hard to see. Each time you power cycle the monitor, the display appears normal for exactly 2 seconds and then goes off. I tried it with multiple computers and the display behaves the same. Any help would be appreciated. Thank you.
    Scholar:
  • 91 Answers
This is known as a failed LCD inverter. If it has a warranty, I would recommend taking it back to where you purchased and request a replacement or get it repaired. Do you know if Kogi is the manufacturer, or is this made by another company, with Kogi as the name? When I find more informationabout Kogi LCD monitors, I'll post a comment to this.
Please let me know what happens and thank you, Binary Bob
Posted on Dec 08, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, lets try determining which is at fault.
  • power supply (unlikely) - the unit powers up, even after the display going off, the monitor is till on;
  • LCD screen (possibly) - will have to be determined later;
  • CCF Lamps (backlights) and/or inverter (most likely) - a check; power on the unit, run through the routine, change channels etc. with a flashlight shine obliquely against the screen. If with the use of the flashlight a darker semblance of the desktop could be seen, then you have just confirmed that it is either the CCFL or the inverter and definitely not the LCD screen.
Good luck and Thank you for using FixYa. Happy Holidays.
My l7eh comes on for a couple seconds then goes black
If you are sure your graphics card is working ok and the VGA cable is firmly plugged into the monitor and card and the power cable is firmly in the monitor, Id suspect the power capacitors in the monitor are blowing or have blown
Dec 30, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi 17'' flat screen monitor
there are four(4) buttons on your monitor to the left of the on/off switch.
Press the first one to the left of the off switch, which will bring up a menu, so you can select
bright or volume, screen size, etc; Next, there are two (2) buttons to the left of the first left button
that you can push to adjust brightness, size, vertical, etc;
Apr 03, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi l7eh-ta ko 17 in
It looks like your power supply is shutting down (terminal overload shutdown) due to excessive current consumption. You need to get a power supply that meets the voltage and current requirements of that monitor or greater current reuirements.
Sep 03, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
No video
sounds like the backlight in the monitor have you tried another monitor?
May 25, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I need a power supply for my Kogi L7EH-TA monitor
I would not recommend this because my monitor will probably burn up from doing this but; I just lost my power supply last night and I took a power cord from my seagate external 500 GB hard drive which has the same pin size plug in that goes into the monitor and plugged it directly into the wall. I assume that the external hard drive uses the same ac to dc converter although it looks just like a cord with no inverter capabilies. Not sure of the amps though and this could burn up the monitor completely. Works for now.
Mar 04, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi monitor bulbs blink on and off
ok,
remove the vga cable from pc and connect it again while running..
regards,
Feb 01, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor not activating
Sounds like will need component-level electronic troubleshooting, probably in the power supply section.
Jan 02, 2007 | HP Pavilion MX70 17" CRT Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
113 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
