Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Bronco looses power after warm up
  • 211 Answers
Check the seals.
regards savumihai71
Posted on Dec 08, 2008
  • Savu Mihai Dec 08, 2008
    Also the spark plug
    cheers savumihai71
    The engine is sealed by the seals,cilinder gasket and crankcase gasket.Hope this helps.
    best regards savumihai71
1985 bronco 2 dies as if key was turned off
The choke has a thermostat spring that keeps it closed until it warms up.
Its possible you have a bad relay or other electrical part that is causing the ignition system to loose power.
May 06, 2013 | Cars & Trucks
I need the torque specs for my valve covers on my 1990 bronco 2 v-6
No torque specs. Don't use sealer, that can cause the gasket to slip. Put cover in place, start all bolts, loosely snug all, hand tighten from bottom two, top two, bottom ends, top ends. Warm up motor and re-tighten (good hand snug) do not over tighten.
Oct 19, 2010 | 1990 Ford Bronco
Why does my 1989 bronco II lose power after it gets warmed up? After taking off from a stop, I have to floor it to get it moving, & it is slow getting up to speed.
does it feel like it is running rough? a mis fire could cause this and if it does it when it warms up you could have a fuel riching mixture problem.
how does it feel>?
Oct 25, 2009 | 1989 Ford Bronco II
Cold starts ok warms up shakes and stalls
check engine coolant temperature when it gets warmer, or at operating temperature, and verify that the temperature gauge is showing warmed up to operating temperature. If the coolant temperature sensor tells the computer the engine is cold it will over fuel and miss and the engine will die. When cooled down it will run fine until it warms up. Also could be coil if it starts missing after warmed up.
Aug 18, 2009 | 1990 Ford Bronco II
1994 bronco 4x4 302cid efi wont start under cold conditions
i would check your starter it may be seazing from the cold
Jan 31, 2009 | 1994 Ford Bronco
Looses power when gets warm
then you need to check your timing
Nov 11, 2008 | 1989 Ford Bronco
87 ford bronco II idling and power problem
check the i.a.c. (idle air control) valve near the throttle body, it fixed my low idle!
Sep 09, 2008 | 1987 Ford Bronco II
You will have to check all the jointed steering parts for excessive play, a front end shop will most likely do this for free if they repair the issue.
Aug 25, 2008 | 1987 Ford Bronco II
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
29 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
