Question about Dell Inspiron 1501 Notebook
It will not turn on
I am trying to remove the case so that I can see the connection from the power button to the mother board I cannot open the case enough. I also inadvertyantly (while trying to get a better view) disconnected the ribbons from the touch pad and the keyboard. Can you help me?
    Master:
  • 461 Answers
I believe the power button connection is part of the palmrest assembly on this model. If by "inadvertyanty disconnected" you mean "broken the connnectors" then I don't know what to say, otherwise you simply reconnect them. The service manual can be downloaded here.
Any reason why you thought there was a problem with the power button connection?
Posted on Dec 08, 2008
Bought new power supply, no difference power button will not even go on or light up ; however small green light on mother board lights up. als accidentaly disconnected the switches wiring to the mother...
The green light just show that the motherboard is getting power.
The power button of the front of the case is connected to the mother board, not to the power supply, usually in the extreme lower left corner along with the with the HDD and Reset Button cords; Power button wire are labeled and usually red/black.
If all wired correctly, possible bad or stuck power button or reset button.
Hope this helps.
Please rate this answer by check rating "Hands"
Feb 08, 2011 | E-Machines T3958 (827103050974) PC Desktop
I press the power button at the front of the tower and it doesn't activate the PC power.
The most common reasons for this are: 1. Switch failure (the button is broken) 2. Power Supply not working
If you can go inside the case of your PC (if confident that you won't mess up with any other thing).
First of all remove all power cords (even the monitor's wire) open up your case again if confident but its better if you get it checked by a technician. By the way to check the switch the method is given below (i expect that you have a reset button)
There must be a wire on which PWR would be written it will be directly connected to the mother board. To get to it look for the button inside the case and follow the wire, when you find the wire carefully take it out and carefully search for the wire of the reset button and connect the reset wire in the place where the power wire was connected.
Plug in all the wires back again cautiously and then press the reset button and check whether now it turns on or not.
If the above method works it means you have a faulty power button and if not then you have either a power supply problem or In some extreme cases the mother board can be burnt.
Mar 25, 2010 | HP Pavilion a620n (PC028A) PC Desktop
Hp 873n desktop opened case to clean, was very dirty (alot of dust bunnys) unpluged and took outside to blow it out with canned air cleaned all fans and entire case pluged in all and fired it off and got 1...
Wow...did you use a vacume anyware near the mother board? the static on the end of a vacume hose is REALLY BAD NEWS TO A MOTHER BOARD.
Try to reseat all cables and plug's. try to boot again.
If that doesn't work try this.
Remove all PCI DEVICES. Try to boot with just the power cable... bare bone mother board....will it post?
If not remove the board from the case...try booting again...if she doesn't boot ast this point , the board took a static hit...she's toast...sry..:)
Please leave feed back
Thanks
Feb 23, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
D865PERL won't power on after power loss. i have two doing the same thing.
Hello there:
The first thing i would check is the power supply if this is not working it needs to be replaced
Also you can unplug the power from the computer and open the case and find the power supply cord that connects to the mother board and dissconnect ti from the mother board ,
now press in on the computer power button and hold for 30 seconds and do the same for the reset button if it has one this will release any (ESD that may have built up ) now just reconnect the motherboard cord that you dissconnected earlier and plug in the power cord to the computer and try to restart
OK? I hope that this has been very helpful for you
Best regards Michael
Nov 16, 2009 | Intel D865PERL Motherboard
Where to plug power button into mother board
Open the case of the server, and look on the side panel that you removed. It should have all of the server options detailed right on the inside of the case for you.
May 22, 2009 | Dell PowerEdge 2500 Server
No pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
May 02, 2009 | Asrock K7S41GX Motherboard
Hi,turned on my AA1 this morning and all i get is a black screen
Perform power drain and check it..
This might be the issue with static charges on the Mother board.
If this is the case, follow the steps and the issue will be resolved.
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Method 2: remove and reseat the RAM modules and check.
Method 3: remove the Battery which is on the mother board and restart the computer and check.
If the issue is still there, then connect the computer to any external desktop monitor and check. I hope the issue is related to the monitor or the Video card. In this case, please contact the nearest service center.
Feb 18, 2009 | Acer Aspire One PC Notebook
Fix the on button on a Gateway laptop (MX7118)
lay down the screen flat
then get the two screws under the power bar
lift up power button bar carfully,you will see ribbon cable connected to the mother board with little brown clips, one on the power button also, this ribbon cable is very thin, and you probably will see the cracks with maginfy, order ribbon cable on ebay
Jan 03, 2009 | Gateway MX7118 Notebook
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
The power led and reset was both on
We have to open the system unit where the motherboard is located, but first pull off the power of your computer so that there will be no ground.
Removed the cover, before touching any part inside the system unit (motherboard) touch first the casing or chas-is of the system unit to removed the static in our body.
Let us first remove the reset wire usually the color is red and black it has a name reset at the connection pin at the mother board usually found at the bottom of the mother board, or follow the reset botton wire found infront of your system unit.
After you have removed, try to plug the power of your computer and turn it on. We can open our computer if the reset connection is off.
That will be the first step to know the cause of the problem. Try also to clean the motherboard using vacuum cleaner the portable only or clean paint brush, cause some of those problem due to dust.
Oct 18, 2008 | ASUS P5P800S Motherboard
Dell Inspiron 1501 Notebook Logo
32 people viewed this question
Alun Cox
