Question about Dell Latitude C400 Notebook
Cuts out every time i put mains lead in
When it shows batterie low and i go to put ny mains lead in it switches the computer of and it dose this everytime so i have to leave it to charge for a while so that i can use my computer without mains its only just started doing this could you please advise what may be the problem
  • tazzo26 Dec 08, 2008
    the mains lead charges the batt when not in use but if we want to use the laptop with the mains lead in it just shuts the computer of totaly
  • 54 Answers
I had a customer with the same problem. Turned out to be his charger was faulty.
I would suggest getting another, or even a test one, maybe the local computer store can test out the laptops charging system while you are there, and if its faulty they can supply you one too.
Posted on Dec 08, 2008
I have a 1990 daihatsu applause. It has not power. The only thing that works is the hazard lights. Battery is good and all the fuses are good.
Have you run a fault code test to see if any thing shows up? You will need to know how to run an OBD1 test, it may require a special tool, not sure due to age of the vehicle
Jun 30, 2016 | Daihatsu Cars & Trucks
My car dose not want to start
the batt could still be low replace your battery if its that bad it probably has a dead cell good luck
Dec 25, 2011 | Nissan Cars & Trucks
My park brack light , disk light and engine foult light com at same time and prevent my car from operating propertly
disconnect battery and join the leads together and leave like this for 5 mins then see what happens when you reconnect them ?'
Jul 02, 2011 | 2005 Jaguar S-Type
I have a 1998 yamaha waverunner XL1200. when i hit the start button it sounds like power going to the starter but won't start. only after the 3rd try. dose it need to be changed.
Corrosion in the leads can do this.Even if the leads look good,they may not be.Every lead needs to be taken off,cleaned,put a protectant on it,and put back together.the main power lead can look 100% but it may not be.My ski had the same issue and a small shake on the main lead showed me it needed fixing.This work costs nothing, but can fix a problem that a shop will charge heaps.Hope this helps
Jun 22, 2010 | Boating
I have a F150 and I replace the fuel pump, Sending
Put the old connector back on,and get the oem pump that installs without cutting and splicing
May 04, 2010 | 1992 Ford F150 SuperCab
I have replaced my fuel pump and cannot get it to run. I measured the voltage at the main connector and I have 7 volts. I have only 3 volts at the pump. Do I need a new sending unit? What should the...
Disconnect your battery. Switch your meter to ohms. Don't let the battery terminals touch the metal body. Put the negitive meter lead on the body and the positive meter lead on the one that is only 3 volts at pump. There should be no continuity. If there is, then there might be a short.
Next try putting one meter lead on the 7 volt main connector and the other on the 3 volt supply side. There should be little resistance. If resistance is high then you might have a break in the ciuciut.
I hope this helps.
Jul 11, 2009 | 1995 Mazda 626
The engine light dose not trun off
Disconnect the postive battery lead wait about 30 and reconnect. If it's a real problem it will come back on, then time to put on computer to find error code.
Mar 27, 2009 | 1998 Chevrolet S-10 Pickup
I put a new battery in my timex WR50M and it is an hour ahead on
With the time showing, hold down the set button for about 3 seconds - it should switch to the city display. Use the receive/start/stop button to select your city (probably CHI) and press set again to save.
Mar 10, 2009 | Timex 1440 Nylon watch
Dell Latitude C400 Notebook Logo
32 people viewed this question
Alun Cox
