Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn Air F7 error msg with incessant beeping
What do I do about the F7 error message? it will go off if I press the cancel/off button, but starts up again in a few moments. If I press the cancel/off plus clock or cancel/off clean. it started after i used the broiler and has been beeping for 2 days. help!!!!! Please.
Thank you, aj
    President:
  • Jenn-Air Master
  • 2,651 Answers
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
Posted on Dec 08, 2008
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
My Jenn-Air oven is driving me crazy. It beeps every few seconds with a -F7 message and tells me to turn off timer clock, which I have never used. I hit it and everything else but nothing stops it. Can you...
F7 means Function Key Shorted or Stuck Button.
Have you tried to Disconnect it for few few, say 30 minutes and then Turn it Back ON. If not try it and also Try to Press Cancel / Clear Buttons, if that help the situation.
Unless, you need to replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 20, 2010 | Jenn-Air Kitchen Ranges
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
F7 error message
f7 is listed as being a stuck membrane switch for longer than 30 seconds, a button is failed and is stuck in. replacemnet is on ly fix you cant repair active overlay switches
Feb 18, 2008 | Jenn-Air SCE30600 Slide-In Electric...
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
F1 shows on display and beeps constantly.
The F1 error code relates to a defective touch pad or clock (ERC). It seems that the reason for it in your case is some liquid entered the unit during its cleaning. Unplug the power cable and wait for few hours, In case it will not help, apart the ERC unit and and dry the touch pad and the clock. Good luck!
Apr 04, 2007 | Jenn-Air JES9800AAS Electric Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
1,344 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
