Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker not making ice
I just received a used Kenmore Elite refrigerator. The freezer is on the bottom and this is also where the ice maker is. The filtered water inside the door is working, but the ice machine isn't. Is there a reset button or a separate water line that has to be connected? What do I do?
  • txsilvertoy Dec 08, 2008
    I've had my kenmore fridge for about 3 years now. We recently had a water softener installed in our home. I was reading the owners manual and it said that could cause the ice maker to stop working. Has anyone else had this same experience?
  • Kymwright Feb 07, 2009
    about six weeks ago I started finding ice that was apparantly dripping out of the freezer maker. Then suddenly the ice maker would not stop making ice, we had to dump out the ice bin regularly so it would not overflow. After about three days of that it stopped altogether. It no longer makes ice.
    Habit-Forming:
  • 171 Answers
Yes, there is 2 lines, one for the water and the other for the ice. you can take the back lower panel behind the frige and take a look at the water line coming from the house where it connects to the frige, you can disconet the line that goes to the freezer, and put the line inside of a container of about 1 litter, and waite for about 30 minutes it at to have some water inside just enough to fill the ice maker. if you donot get any water, replace that valve.
Posted on Dec 11, 2008
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fdfdfs43
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
Kenmore freezer on the bottom. Ice-maker switch is turned on but no ice is being made?
Check your incoming water line for kinks. Make sure the water valve is turned on.
Replace the water filter.
Check inside the freezer and make sure the ice maker power cord is plugged in.
Mar 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker; Kenmore Elite
you have an bad fan motor or wire connection to the fan that is used for the ice maker..hope it helps
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
88 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
