Question about Brother BRTPT65 PT-65 Label Maker Printer
Need help loading cartridge for brother label maker
  • 3 Answers
When you have the label maker upside down...
place the cartridge so the WHITE 12mm ect sign is on top.
pull the tape out a bit and pull it up so that it stick out where the tape would print out of.
place the cover back on tightly and turn on..
push CODE, SPACE, it will feed though and you'll be all set.
Posted on Dec 31, 2008
3 Suggested Answers
Democritus
  • 120 Answers
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Manual is here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Your cassette appears empty or otherwise non-functional. Please see page 2 of the above manual.
Posted on Jul 11, 2008
SOURCE: When I try to print
open the back of the label maker. remove the cartridge. in the lower right hand corner of the where the cartridge fits, there are 3 little posts that are pushed in when you insert the cartridge. find the holes on the cartridge that fit over those posts. cover the holes on the cartridge with tape. reinsert cartridge. try again. worked for me. If you push in the posts individually, you can figure out which one is giving you the error message. I'm not sure that it really makes a difference. I taped over all three holes and it worked fine after that. i realize its not a perfect fix, but may allow you to print anyways!
Posted on Oct 13, 2011
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
My ptouch 1750 gives me an error message that says "no tape!" but i have tape installed. help!
Hi, Make sure that the cartridge is installed and that there is no slack with the ribbon. You can turn the tape by advancing the tape in the center of the cartridge wheel, IN THE DIRECTION of the arrow on the cartridge. You can advance the tape by pressing 2 buttons: CODE and Space
Also if you installed a new cartridge, make sure that you removed the safety cover.
Hope this helps.
The owners manual can be found at this address:
http://www.ptouchdirect.com/ptouch/manual/PT1750.pdf
Have a good day.
Mac =)
Apr 22, 2013 | Brother P-Touch 1750 Label Maker
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
Label maker is printing blank labels when text has been typed in. Need fixed as soon as possible.
1st of all did you check and made sure the cartridge is working fine?
If not try to take the cartridge our of the printer and inspect if the tape is cut, if found to be cut replace it imdly. Take help of the user manual for replacement of the cartridge etc.,
Jul 14, 2011 | Brother P-Touch 1180 Label Printer
When I try to print with my Brother PT-1200 label maker, it says "ERR" and does nothing. I changed batteries and the label cartridge but still nothing.
Jun 08, 2011 | Brother P-Touch PT-1200 Label Printer
My ps 1100 label maker prints only on black side of tape
This depends on the TAPE CARTRIDGE you have in your label printer. Apparenlty, you have a TRANSPARENT TAPE on it, and the printer prints in BLACK only.
Just replace the tape cartridge
Apr 01, 2010 | Brother P-Touch (PT1100SBVP) Label...
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Lost instruction manual brother pt-1000 label maker
Many Thanks. I down loaded the instruction manual then noticed that there are brief instructions on the back of unit.
Jun 23, 2008 | Brother PT-1000 Thermal Label Printer
Loading cartridge
You can download the manual from the link below: http://pub.brother.com/pub/com/ptouch-pdf/UM_PT65.pdf More information with FAQ etc on this link: http://welcome.solutions.brother.com/bsc/public/us/us/en/model_top/p-touch/65eus.html?reg=us&c=us&lang=en&prod=65eus Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 21, 2007 | Brother BRTPT65 PT-65 Label Maker Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
526 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
