Back to:
Tags:
Teac Floppy Drive 235HF Internal Floppy Drive
3.5 Floppy drive (by 3 users)
posted by Max_Harlan on Feb 21, 2007
I have a TEAC 255HF that was working fine until I Upgraded from Windows 98 SE to Windows XP. the Operationg system is the only thing I have changed.
The system recognizes the Drive but tells me every disk (wether new or written via Win 98) is full and I can not format New disk. My device manager in Windows XP shows no problems with the device and says it is working properly. I have used new cables, different Drives that work in Non XP computers. I have uninstalled the drive and drivers and reinstalled them to no avail.
Is ther3e a known problem with XP and internal Floppy drives????
Help
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by xman_1365_x, posted on May 24, 2008
Hi dear ,
Everytime I try to use my floppy drive, I get this message:
A:\ is not accessible.
No ID address mark was found on the floppy disk.
and
my os version is windows xp sp3
please help me for obviation this problem
thanks
-------attach------
winxp sp3
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\>a:
C:\>format a:
Insert new disk for drive A:
and press ENTER when ready...
The type of the file system is RAW.
The new file system is FAT.
Verifying 1.44M
Invalid media or Track 0 bad - disk unusable.
Comment by Guest, posted on Apr 27, 2008
Operating system WinXP, Sempron 1600, TEAC FD works great in PIII WIN95 machine. WINXP says every disk I own is write protected.
Best Solution
posted on Mar 02, 2007
Thanks for Trying (70)
shaky120
Rank:Wiz Wiz
Rating: 85%, 291 votes
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp.
all discs should be compatible, unless you took it from a apple machine for example.
did it work when you put in a new floppy drive?
all the best
John
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 3.5 Floppy drive:
I don't want to Accept this solution
Can you Help with these Floppy Drives problems?
Floppy Drives
1. if a rectangle has a length that is 3cm less than four...
Floppy Drives
A positive number is 5 times another number.If 21 is added...
Floppy Drives
back lite is ok, but no data on display screen
Floppy Drives
The community concert hall is hiring a new agency to sell...
Floppy Drives
The monthly cost (in dollars) of a long-distance phone...
Loading problems.
Repair Service
Find Floppy Drive Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
