Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have replaced the gears
I replaced the worm gear and drive gear on my craftsman 1/2 horse opener. When I first tested it, it sent the door down with such force that it continued to run even after the door was completely shut and this resulted with the upper carriage being sent into the cable pulley near the header board. I released the lower carriage via the emergency release only to find that the door was jammed closed. I had to released the curved door arm from the straight door arm to get the door free. I now have everything mechanically in place (after almost being decapitated when the cable/chain tension released) and now I am a little aprehensive to turn it on in fear that I will get the same result. What might be wrong?
  • 55 Answers
Try backing off the down force and up force pots it sounds like the new gears are working to good, so backing adjusting the pots will make the door stop before it kills anyone. they normally are located side by side and take a screw driver to adjust. They should have an arroww indicating which way makes them use more force.
good luck.
Posted on Dec 10, 2008
Is there any adjustment for the gear drive sprocket that meshes with the worm drive? my gear is not engaging any more
If your drive gear is not meshing with the worm gear it is because it is worn out. You'll need to replace it post haste. The part number is 41A2817 and is available at Sears or any good door opener service company.
Dec 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door motor dead
Keep checking for loose wires. Nothing about changing the gear should cause the motor to stop running. Check the wires on the start capacitor and follow the white wire from the motor and make sure it is connected.
Dec 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp garage door opener, model 139.53970SRT, 8-99 Was working fine, then the plastic drive gear got stripped. I replaced the worm and drive gears and all works great mechanically, except...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
See your post under Garages in the Garden Web.
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need part 41A2817 drive/worm gear kit for Sears
as long as the door is less than ten years old, sears will stock the part you need. you can contact them through this link.
http://www.searspartsdirect.com/partsdirect/index.action?psid=58709328&sid=PSx20071217x00001a
Apr 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor will not open garage door
It sounds like you did a really good job! My Craftsman 1/2 hp gar. dr. opener has a red reset button on it on the l/h side as you are looking at the light/motor from the garage door opening. You have to take the light cover off to be able to see it. My reset button is on the same side as the ground wire. You might check the ground wire while you're there. I really hope that this fixes it for you (and me). I'm quite sure it will as you know your way around the garage door opener already. Good Luck and Let me Know (Please) if it fixed it or not. If I think of anything else, I'll let you know. Have a Good Day!
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
97 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
