HE2 Plus Front Loader is leaking out of the door.
How do I replace the gasket (large gray gasket that seals the door)?
    President:
  • Washing Mach... Master
  • 2,651 Answers
A little patience is needed to replace this, but not terrible hard, youll need to remove the spring clamp holding it to the front panel(peeling back from just at the face youll see it will pop right off, then after that s removed there is another clamp in about hte 2 o;clock position that also needs to be removed, either a phillips, or a 9/32 socket, the new gasket will need to be stretched back over the inner tub rim andtightened( this will take patience as there is not a lot of hand room, and just like changing a bicycle tire as a kid , the rubber will have a tendency to "pop" of the rim until its fully on.
Posted on Dec 08, 2008
My washer has a mildow smell and my clothes smell musty, especially towels!
This is a comin in all front loaders. It it caused by two things not using HE soap and keeping the door closed when not using it. The only way to get rid of the smell is to run 3 to 5 cycles with bleach and no clothes or use a washer cleaner. Most large hardware stores carry them. Once the smell is gone be sure to leave the door open when you are not using it and wipe out the gray boot(gasket/seal) after using.
Jun 03, 2011 | Kenmore HE2 Plus Front Load Washer
How do I remove the door gasket and install a new one? I have the gasket but no instructions. I have a Kenmore HE2.
small inner spring in front lip of door gasket remove and then need to remove large rear band clamp loosen just little enought to pull off boot off clamp screw usually at 3 oclock position
Jan 31, 2011 | Kenmore HE2 Plus Front Load Washer
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
I opened the door on my he2 plus 1104751 and a large retain type wire with a spring was there. I assume this goes around the tub seal to hold it on tight?
Yes, it is used to secure the bellows (door side) of the gasket to the cabinet. If the loop is still intact, you can use a pair of needle nose pliers to reinstall the retaining wire onto the gasket.
If the wire loop is broken, you'll want to get a replacement ASAP to prevent leaking and to prevent damaging the gasket too. They're available from searspartsdirect.com or you can check for a local parts supplier if you wish.
Hope you find this Very Helpful and best regards!
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
My front loading Kenmore H2 has a torn gasket.
You will have to take the door apart to get the gasket mounted properly. Although not required, a second pair of hands really helps.
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
Large gray gasket partly loose with round metal ring coming out the lower area
BoschNexxt Premium WFMC6400UC loose gasket.
This video will show you how to change a door seal on this Bosch front loader washing machine and how to get the parts!
we have all
bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 06, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
667 people viewed this question
Top Washing Machines Experts
