Question about Sony KP-53HS10 TV
Non-HD picture issues
Hello and thank you in advance for any assistance you are able to provide! I have a Sony KP-53HS10 (52" projection) television, and I am experiencing picture problems. Connected to the television are the following: cable, DVD player (input 1), Nintendo GameCube (input 2), and XBox 360 (input 5). The problem I have is this...when watching cable or DVD, or playing GameCube, the picture recently began acting strangely. Sound works fine and the picture does as well for the most part, but I experience lines of static that appear throughout the screen, making the picture appear "fuzzy." The problem persists regardless of how long the television is on, and seems to be a random issue in terms of severity. Sometimes it is bearable with only a few fuzzy lines, while at other times it can get so bad you can hardly tell what is happening on the screen. At first I thought it might be an internal problem of some sort, but the XBox 360 works perfectly. The only difference is that the XBox is of course HD, and the others currently are not. Is it possible for something to go wrong with the television regarding normal display, but not HD display? Any help anyone can offer is greatly appreciated! Thanks again!
  • Kyle Wilmsmeyer Feb 21, 2007
    Sorry. Just realized I forgot another symptom. When the lines are present, they are vertical lines only, and appear to move slightly up and down the screen. Also, you can see "shadows" from the pictures on the screen (i.e. I am watching soccer right now, and all the players have a very faint "double" running alongside them to the left. Thanks again!
Looks like u MAY have a convergence problem. There are 2 convergence settings. One for standard definition and one for HDTV. Go into your menu while in the HD mode and adjust it. Refer to your owners manual for the procedure on your model.
Posted on Feb 26, 2007
  • bob master Feb 26, 2007
    .......do the same in STANDARD def mode.
    Novelist:
    Champion:
  • 236 Answers
Sounds like you may have something generating interference, such as a bad cable shield on maybe a ground connection inside your tv. You might try moving the cables while watching the screen and see if the pattern changes. Double pictures on a screen can be caused by "ghosts", which means that you're getting two signals--- one slightly behind the other. Anything oscillating generating a radio frequency may radiate into your circuits causing this strange problem. Stargazer
Posted on Feb 25, 2007
SOURCE:
The picture is is now in pink
If Sony KP-51ws510 it is an common issue with the picture tubes but there may be a simple way to adjust something in the set to correct this--these had problems with the 3 picture tubes where it can go to excessive red, green or blue.
Confirm model and issue and I will assist.
It only requires a screwdriver and the back does not have to be removed in this case.
Mar 20, 2012 | Sony KP-51WS510 51" Rear Projection...
Image curve
Image curve, it seems tv got problem with convergence output ICs failure.
Do you get off color picture or like 3 pictures in tv screen?
Is it Sony KP-57HW40 rear projection tv?
Let me know above info to provide you helpful info to solve this issue.
Thanks.
Jan 17, 2011 | Sony KP-57HW40 57" Rear Projection...
Our Sony Projection TV has the red color distorted
Double picture symptom shows tv got problem with convergence out section and most probably convergence out chips would be replace to fix this issue.
Though its job of qualified tv tech to replace convergence out chips yet I can provide you helpful info if you are handy with electronics stuff repair and can replace parts in circuit board as soldering work is needed with proper tools to repair tv.
Thanks.
Mar 14, 2010 | Sony KP-51WS510 51" Rear Projection...
On My sony kp 53s75 tv the picture does not fill the whole screen on the HD channels
it is most likely normal--first generation HD sets were 4X3 which means picture is either small left and right or top and bottom; sets which have 16X9 offer full screen HD
Aug 07, 2009 | Sony KP-53S75 53" Rear Projection...
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony kp-53S25 issues please help
The vertical circuit needs to be checked. It could be the vertical output needs to br resolderd or you could possibly have a bad capacitor. if you need more assistance let me know.
May 22, 2008 | Sony KP-53S25 53" Rear Projection...
KP-51HW40 - Picture not Clear
Your problem is a typical convergence problem that happens on almost every tube type projection TV set ever built. There are two Convergence amp IC's that need to be replaced. If you have no TV repair experience, play it safe and call in a pro to assist you in this. Good Luck
Apr 29, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53HS10 TV Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
