Question about Akai PT4298HD Rear Projection Television
My tv flashes red three times and then beeps but no picture no sound. What do I do?
  • 20 Answers
Do not panic! Do not throw your TV away like I wanted to! Here iswhat may be the solution for most of the members who have postedtheir complaints here recently. I am not an expert, but I followed allblogs from various websites and forums, and the conclusion was thesame;replace the convergence board for this model. I purchased itfromwww.partstore.com and since this Akai is the same model as theSamsung Model # HCN4226WX/XAA, buy the Samsung BP95-00142E Convergenceboard for $77. It came to about $85 after shipping. The Convergenceboard has two black STK ICs and two colors of wires, a gray kind and ablue kind, all which have 'pins' and can easily be unplugged fromthe circuit board in the TV. It is basically a complete system thattakes less than 30 minutes to install. It is a simple swap procedure,with no soldering. You only need the new board and a screwdriver! Removethe lower back board of your TV where the cables are plugged in (donot unscrew all the screws for the screen, as it is unnecessary, andmight just damage your screen if you are not careful.) It has a u-likeshape and comes off easy. Detach the gray wires connecting your oldboard to the rest of the circuitry, and detach the blue wires connectingthe old board to the circuitry. On the old board, there are connectorsmarked,from left, blue, green and red. Detach those from the old board,and mark the wires so that you may connect the correct the wires to thenew board. You then unscrew the only screw connecting the board to theTV,and unhook the board from the TV. Hook the new board to the hookswhich held the old board, and screw the lone screw to the board. Plugthe gray cables from the new board to the connectors where the graycables from the old board were,and do so for the blue cables. Connectthe multicolored cables to the blue, green and red, just as was done onthe old board. Reattach the cover and test the TV. Please do notreplacethe two STK ICs only. When I removed my old board, I realizedthat there was a burn mark, where the ICs were, but maybe it was a fuse.You may replace the ICs only to discover that it was another problem.Good luck, and I wish you all the best in the repairs. I just savedabout$100 for a repairman just to show up.
Posted on Dec 11, 2008
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
When i turn on my ps3, the green light stays on and the tv screen doesn't even change. i changed the cords to make sure the audio/video wasn't just out. i tried to enter 'recovery mode' but it won't even...
If you have a "slim" ps3, it does not beep 3 times. Try this.
First, with the system off,plug in your old red, white, yellow cables into the tv. (make sure your tv is on the correct setting). Now, just turn on the ps3 the regular way. Did you hear the sounds it normally makes when booting up (the ps3 boot music?). If so, thats good. If you did not, check again that the tv is on the right channel, and if possible, try another set of red, white, yellow cables.
If you heard sound, but do not get a picture, turn the ps3 back off. After the red light comes on, hold your finger down on the power button for about 5 seconds. If you have a fat ps3, it will beep 3 times after a few seconds to get back to regular tv mode. If you have a slim ps3, it will beep once, then 1 more time a few seconds later. It should reset and turn back on. If your tv is on the right channel and the cables work, then you should now see a picture and you know your audio/video is working. You can now try your HDMI cable and it should prompt you to use the HDMI at this point.
Hope that helps.
Mike!
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
My philips 50p8341 beeps then flashes the red led 4 times
4 Blinks means that an incorrect voltage had been detected on the +5V circuit coming from PSU to digital control board.
The PSU must be tested and eventually repaired or replaced.
Aug 08, 2009 | Philips Televison & Video
What is broken my hdmi cable,ps3 unit or the hdtv?
I would suggest this (you haven't said what kind of tv you have). I have a 37 in vizio, and a 25 vizio flatscreen HD tv. I had my PS3 hooked up using HDMI first time I tried it I got the little pixels you were talking about...so do this. Sounds stupid but it helped me. The HDMI cable where it plugs into the tv plug and unplug a couple times (three times worked for me. Do the same at the PS3 side of the cable. You want to do this with both of the machines off. Also make sure you have the PS3 configured appropriately for your TV settings...There is a way you can auto setup the screen and sound by shutting the PS3 off and holding your finger on the power button for like 5-10 seconds (it will beep twice) then let your finger off the power button.
When my HDMI cable went bad it would go from having a picture and sound to having no sound and a picture, to no sound and no picture. I thought I had a bad HDMI slot...but it was just a bad HDMI cable
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Standby Red Light Flashing
six flashes corresponds to "Horizontal deflection stop". In turn the "supposed malfunction" is then either Q5013 (H OUT) is broken and/or IC507 (H Jungle) is broken.
however i would check
Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510, 516, 524 (A board).
There are actually three C boards, the CR, CG and CB boards. They are attached to the rear of the red, green and blue CRTs, respectively. I wouldnt attempt to repair the set myself. I would solicite the services of an authorized Sony servicenter.
Dec 26, 2007 | Sony KP-53HS10 TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Akai PT4298HD Rear Projection Television Logo
78 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
