Question about Kenmore Washing Machines
Door Locked I have a Kenmore KM HE2 and water is coming out from the liquid dispenser I have called a repair person to come is there any way to get the door to unlock so I can get my clothes out?
  • 750 Answers
Did you try to unplug the unit for five minutes to see if the system resets and the door opens?
Please leave a rating
Posted on Dec 08, 2008
My kenmore he2 front loader is not going threw the wash cycle, but all the lights come on and the door is locked what could be wrong?
Hum may have a bad water pressure switch? It detirmines when the wash cycle should start according to the water level. if bad it will not signal the appliance to start washing. Also may want to check ur door lock switch if its bad it wont go into wash either.
Sep 19, 2014 | Kenmore HE2 Plus 3.6 cu. ft. Super...
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
We have a Kenmore HE2 Plus (110.47511702) that started failing to complete it's cycles and was getting a F21 code. This washer was rarely ever used (we had it in a house we were trying to sell), and...
Welcome to FixYa.
There are several things which can manifest in a "F21" error, however you stated at the bottom the repair person indicated they remedied an "F20" error.
Before proceeding and generalizing on many things which can cause either of these faults, can you verify it is indeed an "F21" error message in the display ?
I will look for your reply and help move you forward in any manner I can.
Regards,
Macmarkus :)
Mar 23, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore 11047511701 Front Load clothes washer: Liquid detergent runs out of dispenser and down front of machine immediately as liquid is poured in instead of holding liquid. Dispenser was not overfilled.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Water in the bleach reservoir after each use
The dispenser door is caked with old soap and not closing all the way. (most likely)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore HE2 Plus Front Load Washer
Bleach and fabric softner despenser liquids not being used.
Feb 25, 2009 | Kenmore HE2 Plus Front Load Washer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Door staying locked
what happen s if you advance the washer too a drain cycle will it drain out the water???perahps its locked from too much water in unit and for safety/flood reasons it will not open. there is a manual release, if hte water level is down to a respectable amount,andto access it youll need to remove the front panel (3s\ screws across the very bottom of the front of the machine) after teh front access panel is removed, you can stick youre hand up the right hand side (where the lock/latch mechanism is) and youll feel a quarter sized plastic tab protruding form hte bottom of the latch assy, simply pull down on it and it will unlock your door for you. reomve the power cord first!!!!
Dec 08, 2008 | Kenmore Washing Machines
Washing Machines Logo
35 people viewed this question
Sal De
fordexpert
Robert Rankin
