Question about Philips VR621CAT VHS/S-VHS playback VCR
Error Code 02 for "99 philips VRB611AT21
I took the top off. The tape is engaged, but will not play, ff, rw or eject. Error Code "02" blinks constant. Can anyone tell me how to retrieve the video without damaging the tape? Thx.
  • Ronald Edward
    Ronald Edward Mar 27, 2009
    same modle same issue with mine. got the tape out and mecanism seems jamed any fixes?
  • Anonymous Jun 03, 2016
    Same problem here. Error Code 02 with tape jammed.
4 Suggested Answers
  • 579 Answers
SOURCE: vr540 philips
- does it load a tape cassette?
- does it rewind or fast forward?
- unplugging it for at least 1 minute should reset the error code.
- if not, there is a serious circuit problem which is not likely worth repairing.
Posted on Dec 28, 2007
  • 125 Answers
SOURCE: Philips DVP 3200V/37
Hey there, Here are some ideas; I would clean it one more time to make sure that its nice and clean try playing a different tape on your VCR and check the channel on your VCR, and thats if you are using a channel 3 or 4 on your VCR, concur with each other. Meaning if you have Channel 3 on your TV you should have Channel 3 on your VCR. Thats a really old method. If you use a coxial cable unplug it and replug it in again sometimes there is no contact at one of the ends therefore disconnecting or connecting it again would help. Just see if that works and usually that was the problem when i use to have problems with my VCR. Let me know if that works out for you alright.
Posted on Oct 04, 2008
  • 25 Answers
SOURCE: wont burn to disc
I don't you can record because you are going from analog to digital with out a conversion proccesor. need to investigate. .type in google problem.
Posted on Mar 12, 2009
  • 347 Answers
SOURCE: VCR plays but stops after 15 seconds. Tape light
open case
clean IR-led which is positioned middle of chassis (goes into tape and sends light sidewards to receivers) and receivers
tryy again
Posted on Feb 07, 2011
Hi i am getting error "Er:03" on the VCR screen. Cant FF/RW/play/eject.
Possibility of mechanism fault inside the VCR, which might include tape damage. Can't answer directly about the 03 code, without knowing make or model number as they all use different fault codes.
Taking the top cover off might show up what's happened.
Nov 21, 2015 | VCRs
Stuck video tape
Is the tape protection guard rotated upward (and the tape engaged with the heads)?
Aug 13, 2008 | Emerson EWV403 VHS VCR
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic VCRs
I've a Mitsubishi HS-U770 that has not been used for several years. When I tried to use it today, the tape loaded but would not play, rewind, or fast forward (I hear what sounds like gears slipping). The...
Mine did that, and when I opened it I found that a small drive belt (visible from the bottom with the cover removed) had deteriorated into goo. This unit had been in storage a while and the rubber just deteriorated, I guess. The trouble is that now I cant tell what size it is, or what length. I think this belt drives the mechanism that loads the tape in and out, and the rest of the mechanism is triggered by the tape cassette moving into position. Since it cant get loaded properly, the rest of the machine doesnt work right, either.
Jan 17, 2011 | Mitsubishi HS-U770 S-VHS VCR
I have sony SLV-X837, the tape wont eject, play or "FF" "REW". has anyone got an idea of what to do or do I need to take to a repair agent? - needyourhelp007
It is quite possible that your drive is not working, the capstan can be fault or the servo is faulty, you will need to check if the motor is running and engaging the drives.
If not possible failures of the rollers or belt is also a chance.
The main mechanism can be taken out after removing the top lid, observe for the tape movement, motor movement while the program is pressed. The tape can be manually ejected after removing mechanism and turning manually the motor.
Oct 22, 2010 | Sony VCRs
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | VCRs
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | VCRs
Sharp VCR Model VC-685U
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
Feb 15, 2008 | VCRs
Philips VR621CAT VHS/S-VHS playback VCR Logo
274 people viewed this question
Top Philips VCRs Experts
Robert McClure
 Grubhead
Grubhead
Are you a Philips VCR Expert? Answer questions, earn points and help others
