Question about Hitachi 43FWX20B 43" Rear Projection Television
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
My DLP is about 5 years old. In recent weeks the color has been gradually changing from what would be considered normal, to a picture with a more blue and yellow hue. It appeared to get worse over time and now the picture is very blue and yellow. Recently, I've replaced the lamp and the color wheel. Neither had any impact on the picture.
What could cause the color to shift over time that's not related to the color wheel?
Thanks in advance for any advice. only have blue and green color. set has to be on a few hours for this to happen. will come back to all colors after 15 minutes, then will be ok the rest of the night.
    Sergeant:
  • 261 Answers
You are missing either red drive signal to CRT or you have a cold / fractured solder joint on the television. Also with the set unplugged check with a non metalic object like a ruler or a wooden spoon and start tapping around in the front or back of set and see what happens. See if you can narrow which area of the set has a problem... Good luck future technician.. Happy holidays.. Jay
Posted on Dec 08, 2008
2 Suggested Answers
electronick
  • 505 Answers
SOURCE: DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
I have a 50" Samsung DLP about 6 years old. Like seagoat, My set is making a "buzzing/humming" sound. Just before it did that I heard a single "pop" sound. For the past week or so the picture has been...
Tv have a colors wheel,hearing a humming or buzzing noises or black&white picture flashes with the picture,the colors wheel is dead.Hire a tv tech. to replaced the colors wheel,it pretty hard to replaced the colors wheel,because have to have take out alots of machanical parts,before even can come to the colors wheel itself to replace it.
Oct 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My tv sceen has a stain that makes anything white look yellow.
The color image is comprised of three colors, Red, Green, and Blue.
All the other colors are mixtures of those colors. The yellow picture indicates that your set is lacking sufficient blue drive.
First of all check to make sure that the tint control is not misadjusted.
The next thing is dependent upon the age of your television. If it's an older set that yellow tint is a sign of an aging picture tube.
If it's a newer set, less than 5 years old, have it analyzed by a electronics technician that is familiar with televisions if he is skilled enough he will know right away if it's the picture tube or not.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
3 year old Mitsubish 52" DLP mdl.WD-52627 TV displays all "Red" colors as Brown-Grey in color. Going to the color level menu and maxing out the Red color bar does no good. Also intensifying...
Found out I have extended warranty and I am awaiting service company to respond in order to conduct service to find the problem.
Thank You
Jun 30, 2008 | Televison & Video
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Color problem with Samsung 40 in LCD HDTV
Check your component cables. You have 3 colors coming in. Red,Green and Blue. Make sure the Red cable is good. You can do this by substituting the red cable only, or just change all 3 cables
Best regards
CircuitCity
Nov 25, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
313 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
