Question about Poulan PP4218AV 18" Chain Saw
Used wrong gas can and ran saw on pure gasoline.
The saw ran and then conked out and won't re-start.
If your saw didnt lock up ,or overheat it should run again, take out spark plug, with switch off, put your thumb over the hole and check for compression when you pull the cord. if it pops your finger off the hole you probably didnt cook the rings, or burnt the piston, the raw gas may have washed the cylinder down enough to temporarily lose compression (lack of oil seal). refill tank with proper gas/oil mix, squirt a small amount of oil in cylinder and pull it thru a few times , this should seal up the rings again , put in a new sparkplug, and try normal cold start, you may have to clean the plug a couple times before it runs. if it runs but lacks power my guess is the rings got to hot and lost their temper or scored the cylinder. dont use alcohol blended gas this will ruin fuel lines , they soften up and fall apart etc. premium regular if you can get it, check the fuel line to be safe for pinholes as they will **** air and not start if you get alcohol blended gas. anyway good luck. geo_1
Posted on Dec 08, 2008
My predator 4000 watt generator was running fine brand new ran out of gas while things were plug in and in use now that I refilled the gas it will not start what's wrong
Are you certain you used the correct fuel ... i.e. gasoline ... and not something else? If correct fuel was added, turn ignition switch to off before trying to restart.
Jan 31, 2015 | Electrical Supplies
I ran I ran out of gas when I put gas in my car it still won't start I really don't know what's wrong with it
Sometimes the pump is damaged when the tank is run dry if it is in the gas tank. The pump uses gasoline for a lube and to keep it cool. Do you know if the pump is working ?
Aug 25, 2014 | Cars & Trucks
Ran out gas now car won t start
Sometimes the pump gets clogged with debris from the bottom of the tank. Sometimes the pump is cooked from lack of liquid gasoline to keep it cool.
Do you have normal fuel pressure at the injectors ?
Aug 13, 2013 | GMC Cars & Trucks
My car has been sitting for 2 years and won't start. The engine turns over but it sounds like not getting gas. I read somewhere to spray gas starting inside air intake valve. Where is the air intake v
Safer is to use 'carburetor cleaner' which is also flammable but a little less dangerous than using gasoline.After sitting a long time, our modern gasoline gets tired; never allow something to sit so long without adding some 'fuel stabilizer.'If possible with your car, I would drain (siphon) the tired gas out and replace it with a few gallons of fresh.
Really tough starting problems can also be overcome with 'starting fluid' which is pure ether and very flammable.Any of these may require the removal of the engine air filter so the liquid gets into the intake manifold.
Stale gasoline can also gum up the fuel injectors which may have to be removed for service if none of the fluids causes the engine to fire.
Nov 23, 2011 | 2005 Jaguar S-Type
I lost the owners manual and wondered if i had to add oil to the gasoline
Yes, you do have to add oil to the gasoline. All two-cycle engines must have oil added to the Gasoline, unless they have an oil injector, and chainsaws do not have an oil injector.
While you do not mention the make of your chainsaw, most modern saws use a fifty to one mix.
Older ones typically used a 25 to one mix, and very old ones used a 16 to 1 mix.
A thirty to one mix will work just fine, since you do not have a manual for your saw, and therefore do not know what the particular manufacturer recommends. You may be able to find out
what your saw takes on the Web, or, maybe from wherever you bought your saw.
Just follow the directions found on the bottle of quality Two-Cycle oil, and add the oil to the gas can.
Do NOT add the oil to the saws tank. You must mix the oil/gas first in a can, THEN fill up your saw.
Jun 20, 2011 | Garden
My chain saw is kicking out alot of smoke, making it quite sluggish, of recent it takes a little longer to start. Having left it a couple of mins. to warm up, it is now conking out when i increase the...
One thing to check is your oil/gasoline mixture. If the gasoline that you used is alcohol enhanced then if you let it sit for a period of time the alcohol evaporates and the mixture changes to more oil than gasoline mixture which makes the exhaust smoke a lot and possibly coats the plug more. Also, regular gasoline that sits in the tank for a long period of time does the same thing.
If your mixture is not at the recommended level,16/1, 40/1 or 60/1 whatever, then the oil will foul the exhaust ports on the saw and back pressure will cause the saw hard to start.
Recommended: take the muffler off of the machine and clean the exhaust ports as much as possible, scraping the built up carbon off. clean the gas tank out removing all of the mixture. Refill the tank with fresh correct mixture. Remove the spark plug and clean or replace being sure that the plug is gapped correctly.
Nov 27, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
Do I have to use ethanol free gasoline?
It had better do so--or any saw brand that fails to run on ethanol blended fuels will see sales fall rapidly in the USA. We, personally, own one of these same saws which (when new) ran great for about 3 days, then refused to start. A trip to the warranty repair station got us a new ignition module. After return, it ran for about two days, then would not start again. The warranty repair then installed a replacement carburetor and about a year later, still seems to be working fine--it's a great hard working saw when it operates correctly. Good luck!
Jul 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain saw will not start
Jun 20, 2009 | Garden
Chain saw emitted sparks and now does not start.
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Poulan PP4218AV 18" Chain Saw Logo
688 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
