Question about Kenmore 17822 Free-standing Dishwasher
I was given a basically new kenmore portable dishwasher with no manual. When I tried to use it, water poured everywhere onto the floor. I don't know how to assemble the correct tubes. Can you help or know where I can get a user manual? (Kenwasher Dishwasher 17822) Thanks!
If you contact kenmore you should be able to get a manual. This may sound silly but the drain hose needs to be draining into the sink.
Posted on Dec 08, 2008
Water was pouring from the bottom of the diswasher, a white part, appears to be a pump is hanging and touching the floor, water pouring from there
un plug it from the power, for your safety. flip it on its back and look at the hanging part. Has tube become disconnected from it?
Dec 16, 2013 | Kenmore 16602 / 16604 / 16609 Built-in...
My dishwasher was pouring out suds onto our floor, why?
useing to much dw soap can cause it to fill it then drain it and again and again till its all gone
May 31, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not draining
Thanks for writing to
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
May 15, 2010 | GE 24 in. Profile PDW7800 Built-in...
Kenmore portable dishwasher not working
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
if you can get underneath it try spinning the motor manually (after turning off the circuit breaker). sometimes the motors on dishwashers get jammed.
May 29, 2009 | Kenmore 22422 Top Load Washer
I just bought a used Kenmore portable dishwasher with Model #587 1749581. I'd like to find an owner's manual and parts list for particular the hose adapters to fit onto a kitchen faucet. Can't...
You should be able to go to the Kenmore web sit and down load a manual. If there is a manual you can get it on line. Try google put the model number right in the search.
Dec 09, 2008 | Dishwashers
Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Jun 08, 2006 | Kenmore 15129 Built-in Dishwasher
Kenmore 17822 Free-standing Dishwasher Logo
197 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
