Question about Symphonic WF803 DVD Player/VCR
Matsui Portable DVD Player pl-800 Error
I have a Portable Dvd Player i put in a disc it says disc loading the disc spins round after a while it goes to stop on the screen wont play any discs .. worked a few days ago any ideas ???
  • 4402 Answers
SOURCE: Matsui Portable DVD player
First Clean the lens:
Posted on Jan 24, 2008
0 characters
1 Points
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
My Mintek 1770 dvd player will not load the disc because when the lid goes down the little plastic pointer does not properly engage the button that starts the DVD spinning when the lid is closed. If I try...
if you look on the top cover inside you should see a round plate that sit on the DVD when you close the cover if this plate press hard or loss it will not have the correct speed in this plate there is a clutch see if its not to lose
hope it will help
Aug 24, 2010 | Mintek MDP-1770 Portable DVD Player
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Portable DVD player .disc error unit spins but says says no disk
Likely to be a classic laser failure. It will require technical person to replace it - try starting with the point of sale and see about warranty etc
Dec 17, 2008 | DVD & Blu-Ray Players
GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Oct 12, 2008 | GPX PDL705
Portable dvd player Film's stop and go back to loading screen
Not sure it's a solution, per se, but I discovered that my Matsui was acting as if I was opening and closing it, so I guessed that it was the lid. Once I put a paperweight on the "Press to Open" part of the lid, the DVD played through. I'm looking how to fix the lid but that's a workaround for now. Best of Luck - M
Jan 26, 2008 | DVD & Blu-Ray Players
Jan 24, 2008 | Symphonic WF803 DVD Player/VCR
Problem loading dvd
replace the lens of your dvd your problems solve
Sep 18, 2007 | Mustek PL-407H Portable DVD Player with...
Disc not spinning
It could depend on the type of media you're using. I noticed that certain types of self made dvd's don't play in this player.
Apr 01, 2007 | Polaroid PDV-0823A Portable DVD Player
Symphonic WF803 DVD Player/VCR Logo
56 people viewed this question
Top Symphonic DVD & Blu-Ray Players Experts
Are you a Symphonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
