Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
MY PC LAPTOP REALSLOW
IM GOING TO ADD 1GB OF MEMORY ALSO IWANT TO REFORMATE THE HARD DRIVE HOW DIFFICULT IS THAT TO DO?
    Scholar:
  • 28 Answers
Unfortunately "real slow" is a subjective analysis and I would need to know what you are comparing it to before going much further. Lots of things could be impacting the performance of your PC or you could just own a slow system (compared to your friend's) and you may need to adjust your expectations (or buy a new PC). However, adding memory can speed up a machine. Clearing out unused files and defragmenting the hard disk will also help. There are lots of tweaks you can do to XP and Vista but they usually only result in marginal performance improvements. You may have a bunch of malware (virus or spyware) running, you may have multiple anti-virus programs, multiple firewall programs, etc. Some people go overboard, not realizing they don't have the extra CPU power needed to run all those programs. Performing a recovery will completely clean out your system and restore it to the factory settings. If the system's original performance from the factory was good this will get you back to that point. (Be sure to back up your data files and system settings before starting the backup though!!)
Posted on Jan 02, 2009
How much memory can I ad to a SR1802HM computer and do I need an external hard drive to handle more memory?
You dont need a extras Hard drive That someting else .. Hard Drive and Memory are two differente Thing... Go on the Net and Exemple... Type Compaq Presario SR1802HM.. Manual & Spec, You will get all the information your need for it ....
Sep 22, 2010 | Compaq CPQ SR1802HM PRESARIO DESKTOP...
Can i upgraded my acer aspire one pro P531h-0Bk netbook
The first models of acer aspire one pro P531h-0Bk is not able to get more than 1gb RAM, but the revised model is able to get this. So you MUST consult with your IT dealer.
You can upgrade your Hard disk.
Sep 26, 2009 | Acer Aspire One PC Notebook
I recently had my hard drive reformated and a
You can change the mouse seetngs by going into
Start-> Control Panel-> Mouse
Click on that and you will have a mouse properties dialog box.
In pointer options tab select the pointer speed you desire.
This will help restore the pointer to its normal speed
Jul 12, 2009 | HP Pavilion dv4000 Notebook
Hard disk and ram
Hello Kevin Shaggy...
Let me see if I can help you out a bit...
Adding a 160gb to a 40gb does give you 200gb. BUT!!! you will loose a little bit on each one after formatting the harddrive. The new drive will wind up being about 157 or 159gb give or take a little.
ANY harddrive partition, whether it is a c:, d:, etc...you DO have to format EACH drive letter.
If you partition your 160gb harddrive into 2 parts, (2) 80gb drives, then they would get two drive letters and both of them get formatted.
IF the 40gb drive is C: then the new 160gb partitioned in half would be D: & E:.
CDROM Drive would be F: and so on....
Floppy Drives, CDrom Drives, DVD Drives, you do not have to format like a hard drive...
If you add a 1gb stick of memory to your existing 256mb stick of memory then you WOULD have 1gb + 256mb. If you remove the 256mb and just add 1gb, then you would just have 1gb.
Nov 24, 2008 | Samsung Computers & Internet
Question
First, you will not be able to upgrade the video card on your laptop, since video cards for laptops are specifically designed to fit onto the motherboard and the design of the laptops body.
Secondly, sound cards as well are also deisgined that way, some sound cards on laptops are built in to the mother board and higher end sound card for laptops are specifically designed to fit onto the motherboard and the laptop's body.
Hard Drives on the other hand can be upgraded to a higher capacity but you can't add an additional Hard Drive. I have checked the specs of your laptop has 80GB IDE. You can upgrade to 120GB IDE or higher if you like. Just make sure that you purchase a 2.5" HDD (5400RPM/7200RPM speeds).
Here are examples of Hard drivers that you need for upgrade. I checked newegg.com for available laptop hard drive. You can check other online stores or other computer shops near you if you as well.
links (Hard Drive) :
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136130
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148073
http://www.newegg.com/Product/Product.aspx?Item=N82E16822146200
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136114
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148130
**Since you have installed Windows Vista, I suggest that you upgrade the RAM (Memory) on the laptop for smooth performance for Windows Vista. The maximum memory on your laptop is 2GB DDR SDRAM. Buyin RAM for laptops are a little but tricky so you can just go to the link below for specific memory upgrade for your laptop (I suggest that you purchase 2 pcs of 1GB since your system can accomodate up to 2GB).
Link for RAM (Memory) :
http://www.edgetechcorp.com/memory/upgrade.asp?cid=29695
**If you decied to upgrade the Hard Drive, you can still use you old Hard Drive as an USB external Hard drive for storage purposes. You will just have to purchase a 2.5" External Hard Drive Enclosure. Click on the link below for the example of the product :
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145136
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145329
**If you can't click on the links, just copy the link and paste it to your's browser's address bar.
Oct 28, 2008 | Sony VAIO PCG-GRT360ZG Notebook
Hi there I just brought a mikomi gp-311a 4 port usb hub for my aspire 5315 laptop (1gb). After root hub installed sucessfully,i added my other usb devices into the hub and it is not regonising any of my...
The problem is that some usb hub devices are not powered enough to recognise peripherals, i always recommend buying a mains powered usb hub as the pc's supply can find it difficult to power the usb ports enough as well as powering other components in your pc.
Sep 12, 2008 | Computers & Internet
Slow computer
YOu computer meet the average power requirement nowadays. HOwever if you want to make more faster performance. U only need to add more memory. 1Gb is faster than my computer which is 512Mb.
Ok adding more memory make the computer faster from 1 Gb to 2GB this is much faster.
hard drive is nothing to do with the performance of the system. its only a storage of all files.
but besure to know the model of the memory before you buy. it should be identical to your current memory.
melnavz
Jul 16, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
HP Pavilion dv2000
This model laptop will not allow you to add a video card to it. The video card and all of its components are part of the Laptop motherboard already.
You can, however upgrade your memory from the 1GB up to a total of 2GB, but your current configuration is 2x512mb chips.
So right now you have 2 memory slots available but they are being used by the 2 512mb chips. You will have to remove them and replace them with 2 1gb chips. This can be fairly pricey.
Here is a link to your computer specs
http://h10010.www1.hp.com/wwpc/au/en/ho/WF06a/1090709-1116637-1116665-1116665-1116665-12435984.html
Apr 27, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
