Question about Makita 5" Disc Sander GV5000
Makita gv5000 5" disc sander won't work
I plugged in my sander and it worked for a few seconds then stopped. I had tripped a breaker. After switching the breaker back on the sander still would not work. I have tried the sander in other outlets in the barn and house since then and it doesn't work. Nothing happens when I plug it in and depress the trigger. I don't have the manual anymore. Does the sander have an internal fuse or something? This sander has had just light use over it's life. Thanks for any advice, Joan F.
  • monkeypuzl Dec 11, 2008
    OK, I'll do that. Thank you very much.
  • Anonymous Mar 31, 2014
    the rear bearing is destroyed, how do I remove the old bearing from the shaft. It seems stuck hard
  • 23 Answers
There isn't an internal fuse. by the sounds of it you probably have a short, a bad brush, or some arcing.
if you use your sander for fine sanding (100+ grit paper) you have to make sure to clean out the motor housing. Fine sanding dust, like any fine dust, creates alot of heat when aerated and can melt the plastic brush holders or can cause the electricity to arc from one wire to another inside the housing.
my advice is to take the 8 (i think it's 8) screws out of the side of the gun and carefully pull the halves apart. there isnt alot you can mess up inside and just visually inspect the wires for burns or melting on the brush holder.
here's a breakdown if you need it.
if you find something inside that you're not sure of, or if you have any additional info i'll keep checking in on this.
Posted on Dec 10, 2008
Fix sander
You likely have something bound up or a bad bearing. Take the belt off and turn things by hand to verify they work smoothly
Apr 16, 2014 | Jet 414551 J-4200A Industrial Disc Belt...
Clarke sander
Once we plugged it into an outlet with a trip switch it worked.
Jul 28, 2013 | Tools & Hardware - Others
Oscillating drum sander runs a few minutes and stops
This usually occurs if the motor is overheating and the internal circuit breaker is tripping. After it cools down, it self resets. This can be caused by bad bearings or parts dragging the motor down, making it work hard enough to over heat and trip the breaker. If you are running it on an extension cord or circuit that isn't able to provide it with the amps it needs the motor will overheat and trip the breaker also.
Dec 02, 2012 | Delta 17-960 Oscillating Spindle Sander...
My blade to my circular saw model number 5007nb was having trouble cutting through some wood which lead to it over heating how can i fix this thing and get it to start working tonight
Well you did not really say what is wrong?
Are you trying to stop the overheating, or did it get so bogged down from blade heat warpage, that the internal circuit breaker tripped?
If so, then look at the end of the motor, near the cooling vents, and press the little black circuit breaker reset. (not all have them)
Also check that the outlet still works, by plugging something else into it, because you may have tripped the circuit breaker for the outlet, or GFP.
Mar 12, 2011 | Makita K06 Switch 5007fk 5007nb 5007s...
I have a MS1000 Black and Decker Cyclone round sander..looking for replacement sanding disc
Hello, W/D here.
Most sanding disc types are available at the larger box hardware stores. They are (sometimes) generic or exact replacements.
I use the "Gator" brand on my B7D sander, and the discs work just fine.
Best regards, --W/D--
Feb 23, 2011 | Black & Decker Black And Decker Cyclone 4...
Disc won't adhear to pad
I have had this happen twice (I use the sander quitder e a bit.) The sander pad needs to be replaced. Dixieline (Probuilders) stocks them or you can or order it on line at .
Nov 28, 2010 | Makita BO5010K Random Orbit Sander, 2 Amp,...
Makita 5" Disc Sander GV5000 Logo
350 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
