Question about Panasonic Microwave Ovens
Microwave dimension 4 shut down completely. can you supply ovenlayout and partslist
    Sergeant:
    Champion:
  • 283 Answers
Hi,Please dont rate me if this could not fix your problem. Before anything else, Check first the fuse. If doesnt work post for more information. Thank you.....
Posted on Dec 08, 2008
  • 6,487 Answers
This link may be helpful to you since there's no online resource for this device http://www.microwavecooking.com/Kenmore_Microwave_Parts.htm
My Kitchenaide KEMC378KSS0 Oven Microwave Combo shut down.
Is it possible the cord got knocked loose during the work?
The parts list with exploded views is here.
My site is MicrowaveControl.com so feel free to e-Mail me at pupista@gmail.com for details and free advice.
Sep 27, 2016 | Microwave Ovens
How can I restart my microwave?
Hai, this is a diffucult thing which can maje you buy anew one cause of electronics devices in it,but ithink you can check your fuses case the top one is controlling the supply abd you can also check yo magnetron, capacitor, thx
Sep 13, 2014 | Galanz P70D20AL-T1 .7CUFT White Microwave
Stops after 4 mins
Can you hear the "whirl" of the fan? It is possible the fan is not turning & cooling the oven therefore it will shut down when it reaches a certain temperature. This could be caused by a supply fault to the fan or the fan motor, either way it would need to be tested by a qulified engineer.
Nov 10, 2013 | GE JVM1653 Microwave Oven
What are the dimensions of the Whirlpool microwave GH4155XPB?
Dimensions/Weight Exterior Dimensions (WxHxD): 29 15/16" x 16 1/4" x 15 7/16" Cavity Dimensions (WxHxD): 22 3/8" x 8 3/16" x 13 13/16" Approximate Shipping Weight (lbs.): 86 Microwave Capacity (cu. ft.): 1.5 Cooking Power (watts): 1000
Jun 06, 2011 | Whirlpool GH4155XP Microwave Oven
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
I have a panasonic dimension 4 turbo bake microwave model nn-a774sbbpq when switching on it runs for approx. 20 seconds and shuts off this time factor is always the same any ideas?
The uPC system is sensing a failure of some type. This could be that the magnetron is not emitting to specificaitions, or one of the power supplies are not operating in specs.
This is not something you can fix yourself. You will have to take the microwave oven to a service center to have an estimate for repair. If the unit is out of warranty, it may not be worth to service.
In case you get curious, I would never suggest for you to open the encosure of a microwave oven. There are very serious safety issues with working in this type of appliance.
Jerry G.
Sep 02, 2008 | Panasonic Microwave Ovens
Panasonic Dimension 4 Turbo Bake Microwave oven. Everything works except the microwave element. Why?
Your Magnatron is most likely to have failed, its an expensive part and on a turbo 4 could be 2M236-M42. Unfortunatly this appears to fail due to reduced air flow. So if you do replace it I would clean the rear grills completely to increase the airflow within the oven.
Apr 14, 2008 | Microwave Ovens
Magic chef over the oven microwave shuts off.
Is not normal for a microwave to shutdown after 4 minutes of operation.
From the info you are providing, It looks like the magnetron might be overheating causing the thermal fuse to shut it down until it cools down. There may also be a loose connection in one of the switches or a cold solder joint in the low voltage power supply.
I would suggest to check and make sure that the fans are functional, If always did; it could be that there isn't much air circulation where the appliance was installed.
Mar 03, 2008 | Microwave Ovens
Dead Microwave Oven
Remove the top cover of oven, there should be tec screws on the bottem of unit to remove the cover, check for bad relays,fuses and fuseable links that could have finaly gone bad.
Jan 13, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
