Repeated failure of the aluminum hub which carries the spin tub. It appears to be eaten away by water or detergent. Casting pockets are filled with what appaers to be dried detergent residue in spite of using only liquid detergent. Second failure in less than 24 months.
  • 1 more comment
  • Anonymous Dec 08, 2008
    Kenmore 41742142100 Front Loader washer had the tub support bracket break off two of the three legs when machine was 4 1/2 years old. Now, 1 1/2 years later, the bearings on rear shell failed. We also have used only liquid detergent with softened water. Are there any "class action lawsuits" in process for this problem which I can "piggy back" on? I'd be happy just to recover parts cost as we love the washer when it's working. I just purchased the rear shell w/bearings and seal and found the support bracket from just 1 1/2 years ago beginning to "pocket"/deteriate! So, I'm going to clean it up and paint it with epoxy/appliance paint to ward off this erroding hopefully. Too bad Sears/Fridgedaire are not listening to our cries. It's going to cost them many customers from what have read on Goggle and you can add my wife and I to the list!
  • Horsefly441 Dec 11, 2008
    After reading Goggles comments from many disgruntled Sears/Fridgidaire front loaders, the common theme of it doesn't matter if you use city water, well water, liquid detergent, powder detergent, cold water, hot water, etc.,these washer "spin tub support brackets should not be deteriating. I can see clothes not getting cleaned properly, over use of soap not being rinsed out, mold growing in machine, all of that, but, the tub bracket should not rot! They should have made it out of stainless, same material as the spin tub. Thanks for your help though. We'll try harder to "baby" the machine to see if it will give a couple more years of service. Horsefly
  • Ron Coons
    Ron Coons May 11, 2010
    whats the model and manufacture of unit?? and how exactly is the hub failing???
  • Washing Mach... Master
  • 3,463 Answers
The major cause of drum support failure is the use of todays modern powders and detergents, also .
another major factor is washing at too low a temperature.
At low temp washes , some of the active ingredients do not function at low temps..You need to change your washing habits.
Always follow the instructions on the wash powder manufacturers products, and at least once amonth do what is called a maintenance wash,this is putting the washer on at a high temp, with powder in, but no clothes.
This helps to keep the inside components clean
Another factor is using biological and non biological powders,
Posted on Dec 08, 2008
Build up of dirt in tub making clothes dirty... How do I clean inside of machine?
If you use powder detergent ( clay carrier) the build up is from undissolved powder ( clay)
It forms cakes between the spin tub and the outer bowl
The fix is to pull the washer apart and physically remove the caked up mud from all parts of the machine
The prevention of future mud is to use liquid detergents rather than powders
It works like this powder detergents have a small percentage of actual detergent in use and that is dried onto a clay base as a transporter agent
In the wash , the detergent is released but the clay will not dissolve
Most is pumped out with each spin but a certain amount remains , dries and starts the dirt process through the clothes
With liquid detergents there is the same amount of actual detergent but the carrier is water and that is diluted in the spin and completely flushed away
Dec 30, 2015 | Washing Machines
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Machine making a knocking noise during spin cycle. The drum shaft has alot of free play front to rear and I suspect that is where the problem resides.
If your machine is making louder than normal noise during spin it could be the failure of the basket. Mine is just under three years old and the basket became looser than normal in the tub. I diassembled the machine...a lot of work...and found the aluminum casting around the shaft and bolted to the basket had rotted away. It looks like it was attacked by the bleach since I had my water checked and its pH is fine. It is likely the root of the smell we have experienced with our clothes when they sit too long in the machine. I spoke with GE and they gladly agreed to replace the parts needed but it is a ton of work to install them. I plan to treat the new part with some zinc chromate if I can get some before the parts arrive. See the picture if it attached correctly.
cid:07d1be63-2d47-407a-89ca-6090b4131d58
Nov 16, 2009 | GE WSXH208A Front Load Washer
As the washer is filling with water, it overflows out of the dispenser area. it appears that the water is not getting into the machine quick enough as the dispenser fills with water.
hi there......this problem is usually caused by a build up of detergent in the hose leading from the soa disenser into the wash tub....remove the soap dispenser....check for accumulated detergent under the drawer....and in the top of the fill hose....easy removed with a little patience and warm water....
regards Sir Galahad
Aug 16, 2009 | Washing Machines
Small amt of water drips into tub after washer stops fisher payke
If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
  • thanks and please do not forget to accept the solution
Apr 03, 2009 | Fisher Washing Machines
Amana washer model LW6501W2 leaks in front during fill up
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
Apr 01, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Kenmore Elite HE3 water problem
These washers are designed to use less water (about 5 to 7 gallons) per washload as opposed to the standard 35 gallon capacity of top loaders. That's why they are considered High Efficiency washers. They use less water, less electricity to run, and spin at a higher rate to extract as much water from your clothing as possible. That's also why the use of HE detergent is mandatory with these units. The detergent is formulated to be used with washers that use less water. If you are using standard detergent you are, in affect, putting a higher concentration of soap in the washer, because it is formulated for use in a 35 gallon capacity tub. This can cause the premature failure of gaskets, seals and the drain pump, as well as, leaving residual soap in your clothes. Now...I'm not accusing you of improperly using your appliance. I'm merely giving you information that a lot of consumers just don't realize.
I don't know how others have been adding water to the wash tub, unless they stop the unit and pour water in the tub. I personally would not recommend it, because you're deluting the detergent in the process. The detergent has cleansers and suspenders that help clean your clothing and help suspend the dirt away from your clothes. Adding water would only reduce the cleaning ability of the detergent you are using. Also, take note of the HE detergent you do use. Some of them are double (2X) and triple (3X) concentrated. Which means you only have to use a little to do the same job.
I personally own one of these washers and have never had a problem with getting clothes clean by using HE detergent with the current water per load capacity. I hope this helps you. Let me know if you still have questions.
Nov 13, 2008 | Washing Machines
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
LG Front Loading Washer overflows at detergent dispenser
you mean where you put the regular HE soap in? That slot is normal to overflow. The water carries the soap down (Lift the little doohickie up, it's removable for powder deterg.), and it carries it all the way to the tub...Unless i don't get it...but I'm reading the phrase "Its like the water will not go down to the tub.", and it makes me think the whole tray is overfilling with water..if this is the case, I can't help you, but filling over of the Main HE Soap tray is normal. (Just a little, if the whole thing starts filling uncontrollably, hit the power button.)
Feb 10, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
252 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
