Question about Casio Exilim EX-S500 Digital Camera
Lens Then lens on the camera is stuck at comiong out to about 1mm, is there anyway i can repair this? Please help soon! Jen
    Novelist:
  • 107 Answers
Jammed lenses are generally caused by either an impact that knocks the rings out of alignment, contamination of sand or other debris in the motor drive, or a malfunction in the drive system causing the camera to loose track of what position the lens is in. If _gentle_ manipulation of the lens does not free it then you will have to take or send the camera to a repair facility. David Millier Advance Camera Repair
Posted on Feb 24, 2007
My lens will not come out?
Fixing a Lens Error - Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/.../fixing-lens-error-on-digital-camera.html
Dec 22, 2007 - Many camera makers will not honor repairing this problem under ..... i can view my pictures, and the lens does not come out, but when i just turn ...
Contact Stuck in My Eye: Please Help! - AllAboutVision.com
www.allaboutvision.com > Contact Lenses > FAQs
This can help "draw out" the stuck lens to the center of the eye where it can be easily removed. ... When the Contact Stuck in Your Eye Won't Come Out. If none of ...
Camera lens stuck? How to fix! - YouTube
? 3:01
https://www.youtube.com/watch?v=vJ6PLb21enY
May 31, 2011 - Uploaded by gearlock trinity
My camera telescopic lens was stuck and I fixed it, hope this helps! ... and I try it but won't work! and the ...
Jan 17, 2016 | Nikon COOLPIX L820 Digital Camera Deluxe...
My samsung ES60 camera lens comes out around 1mm then beeps and turns the camera of, rarely it comes out and when it does it takes pictures fine, but the lens is stuck most of the time.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 08, 2010 | Cameras
Camera lens stuck!
Hello Friend,
First i would let you know that the Brand Vivitar is one of low quality cameras, it's sad but it's true.
Now regarding the issue that you have with the lens, you probably drop it because this the only way to have the lens stuck. but anyway, to repair it it will cost you more than a new one. and again i suggest to buy a branded camera like Canon,Sony,Nikon,Panasonic ... these are top quality cameras and you will not have any problem for life except if you drop it ;)
Best Regards,
Oct 29, 2009 | Vivitar ViviCam 4345 Digital Camera
Lens problem
the lens needs replacement.
for reparing estimates cost of camera
http://www.advancecamera.com/repair
the link will help you to get the device repaired and serviced
· Free estimates.
· Reasonable rates.
· Fast, friendly, and personal service.
· Top quality repairs.
· Advance Camera 1 Year Warranty
Apr 01, 2009 | Canon PowerShot SD1000 Digital Camera
Whenever I open my camera, it says zoom error
Your lens is jammed. you need to strip your camera down to access and remove the lens unit. BECAREFULL of electric shock. your camera will still have charge in the flash unit and you will recieve quite a shock if you touch the board or any components inside. You will also have to purchase a "tri-wing" screw driver for the case screws. These can be sourced on ebay.
Don't rush with your lens unit, it is likely that it has damage to the sliding assembly due to the impact. take your time and don't use excessive force. your lens will only dissassemble once it is in the retracted position so patients is required to free it off otherwise more, if not terminal, damage will result. Try and use another camera to photograph each stage of dissassembly to aid reassembly later. You will need :
small cross head screw driver
tweezers, pointed prefferably
Tri-wing screwdriver for the security screws
Soldering iron with no more than a 1mm tip and some solder and solder braid for desoldering.
If you discover broken plastic inside your lens or too much damage then I may be able to help you out with either spares or help with repairing
Mar 19, 2009 | Fuji FinePix A800 Digital Camera
Lens Broken
the lens is what the camers sees somewhat like the human eyeball, you loose your eye you can't see, brake the lens the camera cant see
Jan 03, 2009 | Cameras
Can't open web site http://www.e18error.com/repair.html
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 02, 2008 | Canon PowerShot A80 Digital Camera
Lens stuck open
In a nutshell, this error happens when the lens gets stuck while trying to extend and comes slightly out of alignment. Particularly if it's been dropped while open. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty, the best thing you can do have Polaroid should fix it. If your camera is out of warranty, or if Polaroid refuses to repair it for free, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Dec 04, 2007 | Polaroid i832 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
147 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
