Question about LG DLE2514 Electric Dryer
NO HEAT from lg 2515s dryer
No-matter what you set the dryer on there is no heat
Your heating element is burned out.
Posted on Dec 08, 2008
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Model mdg5806aww maytag dryer works but heat is a hit or miss. Works ok for a few min then cold air, no matter what setting is set.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Maytag Dryers
My LG dryer is electric, model# DLE3733W The heat doesn't work, all lights on the panel come on according what I set it at. I can then unplug the power supply and plug back up and the heat works until the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 06, 2010 | LG DLE2532W Electric Dryer
LG Dryer displays CL on screen. What to do?
Makes no mention in the manual about a CL error
Apr 01, 2010 | LG DLE2516 Electric Dryer
My dryer runs at a very high heat regardless of the setting. What needs to be replaced?
Unless I am wrong, I believe the heat in a dryer is either ON or OFF ... there is no "gentle heat" as such. Most dryers achieve 'gentle heat' (or any heat setting, for that matter) by cycling the heat on and off for certain periods of time.
Which is not to say that your dryer is not malfunctioning. If you continue to believe your dryer is not under control, you probably cannot repair it, the on and off cycle being regulated by a variety of delicate sensors.
I suggest if you suspect you are having out of control heat with your machine, it may be time to call the professional to have a look-see.
Thank you for posting your question at FixYa.com
Dec 24, 2009 | Dryers
Our Whirlpool Dryer Will not heat at all and not
Your timer may be the cause of both problems. Not cycling and no heat.
Whirlpool makes a excellent dryer and is worth repairing. Replace the timer first. If you still have a heat problem most of the other parts are around $30.
Nov 09, 2009 | Whirlpool Dryers
Wet clothes take two 'trips' to dry.
UNPLUG THE DRYER THEN PRESS THE MORE TIME , AND THE LESS TIME BUTTONS AND THE POWER BUTTON FOR ABOUT 10 SECONDS. THEN WAIT FOR 3-5 MINUTES THEN PLUG THE DRYER BACK UP . SEE IF THAT WORKS BY THAT RESET.
Dec 01, 2008 | LG DLE2514 Electric Dryer
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG DLE2514 Electric Dryer Logo
94 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
