No picture Blinks quick white flash once when first turned on and goes black. Has good sound.On all inputs.
  • 2 more comments
  • dctc1 Dec 08, 2008
    Magnavox 32MF605W/17
    It is 3 years old.
  • dctc1 Dec 27, 2008
    Blinks quick white flash once when first turned on and goes black. Has good sound.Tryed video on all inputs.Replaced LCD controller still the same.
    Sergeant:
  • 306 Answers
Your TV has a power supply board and inverter board. The inverter board provides the supply to the small lights around your screen which make it bright so that you can see the image. When the voltage of this inverter goes higher than normal, there is a feedback signal that is fed to thepower supply section that shuts down your TV. Sometimes there are solder connections on the inverter board that become loose due to the heat generated by the coils(small ballasts). Resoldering them would fix the problem. If checking it visually doesn't show any loose connection, the next step is to replace the inverter board.
Have it checked by a qualified repairman.
Posted on Dec 27, 2008
  • AbdulRahiman S Dec 27, 2008
    id look in the  area of the large signal board
    that will be the one with the flyback and power supply and deflection circuits on it  to your right
    flybacks are known to fail on these models as well as a high voltage leak
    was the set popping from time to time ?
    else
    When you turn your set on can you feel any static electricity from the tube at all
    to repair an unit without schematic over it it like walking out in the deep forest without
    an compass/map try www.eservinfo.com search for the model/brand maybe you can find
    it there...
    Most common is bad solderings around the high voltage transformer and the surrounding components can lead to shorted H.O.T the transistor who "feeds" the
    transformer one tip when you work with this kind of things keep one of your hands on your back ! otherwise you can lead the voltage/current thru you heart
    Bad solderings come with the time the machine heats up cools down vibrations etc
    sooner or later you will find cracks around the component legs/pads like an "o" but very faded
    I will tell you a rule of thumb about something being worth repairing;
    First it does not matter how old is it unless the CRT shows burned or the picture being washed out.
    Second look at how much it will cost the repair versus replacing it by a new one.
    Third most repairs should carry a 3 months guaranty.
    Now, your TV is energizing the relay (that is the clicking sound) as it was said it could be the 'high voltage shut down' circuit that is activating the power shut down or the HVSD could be ativated by an overload some where in the power supply or the HV horizontal if it is a CRT type. If you don't have the schematic is going to be guessing. You should get a free estimate from a repair shop.
    The highest CCFL inverter supply that I have seen it had 830 Volts, the big majority are around 350 V.
  • 365 Answers
May be due to the improper supply of current,may due to the circuit board compliant,may due to the damaged input cables,due to some problem with the displaying device,burnt off capacitors etc.try to check it.thank you
  • JITHIN ANTONY Dec 31, 2008
    does the problem solved
  • 15,935 Answers
That's probably a bad inverter. I can't remember if the inverter is available seperate or if it's part of the panel though
  • blueextc3221
    blueextc3221 Dec 27, 2008
    this can be one of the inverters, a failed CF lamp or the panel itself doing this - i threw 3 of these in the trash this week for bad inverters because philips will not offer any support for there own products
  • blueextc3221
    they are "throw away" cheapo units unless you have another bad one with a different problem you can salvage from.
    Master:
  • 505 Answers
If the screen says no signal, check the video input cable.
If the screen is totally black but you are getting sound then the problem is with the Digital processing board or LCD controller and its has to be repaired. I am sending the link for parts list and place from where you can repair.
http://www.shopjimmy.com/TVs/Panasonic/Panasonic-TV-Parts.html
Thanks
Posted on Dec 08, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, lets try determining which is at fault.
  • power supply (unlikely) - the unit powers up, there is audio;
  • logic/controller board (unlikely) - presumably the remote works, you can change source/input and again presumably the controls work, channel up/down, volume up/down;
  • LCD screen (possibly, but rarely) - will have to be determined later;
  • CCF Lamps (backlights) and/or inverter (most likely) - a check; power on the unit, run through the routine, change channels etc. with a flashlight shine obliquely against the screen, increase/decrease the volume level. Shine the flashlight where the volume level/indicator is normally displayed. If with the use of the flashlight a darker semblance of the volume level could be seen, then you have just confirmed that it is either the CCFL or the inverter and definitely not the LCD screen.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
    Champion:
  • 283 Answers
Hi,please dont rate me if this could not fix your problem. Initially check the fly back and the tv lump.Since it has a good sounds absolutely its not the fuse. Thank you POst for mor details....
  • 470 Answers
Maybe the ATV is finicky with it's cables. I could try hooking it up via component and see if I get the same results.just check the inverter or the flash capacitor my dear,, regards JAN_yuanjia
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 01, 2009
    review the plyback on it,, make sure it is not burn or the capacitor cannot sustain energy current of it
    Antonio Buenafe Jr. Jan 03, 2009
    oes the problem solve my dear?? you chack the capaitor? or either the plyback?
    Genius:
  • 1,550 Answers
Did you check the fuse and inverter on your tv ?
How old is your tv ?
Chance of faulty capacitor on the power board .
  • 6,487 Answers
Can you please provide us the brand and model of your unit so we can help you better with your concern...and you can also try first to unplug the TV for about overnight to let it reset itself....
Model 32ld452c. Why is there a black screen and no sound?
Sounds like main digital board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sep 06, 2015 | LG Televison & Video
Have a 65'' mitsubishi model #WS65411. Screen goes from a good coloered picture to black screen & keeps flashing back&forth between the two.
Ok so you have a projector pointing at a 65'' Screen?
Where is the projector receiving input from ?
Did you hust get this projector ?
please add more details so that we may be of quick and thorough assistance.
Jan 14, 2008 | Televison & Video
My tv has sound, but no picture. When I turn it on the blue light blinks eight times and the screen is black. What is wrong?
Hi Tammy,
Please check the INPUT of your TV by pressing INPUT, SOURCE or TV/VIDEO on your TV remote. Once you press one of those ( that was on your TV remote ) you should have INPUT lists on your TV screen. All you have to do is select each one on the list until you get a picture ( normally input is TV ). Hope it helps.
May 05, 2014 | Hitachi UltraVision 55HDS69 55 in. Plasma...
My Coby LEDTV 1926 blinks red, green, blue, white, and black. Is there anyway to fix this?
Sorry I can't help, but mine does the same thing sometimes. It'll work fine for awhile, then no picture, but goes crazy and flashes one color at a time across the whole display, very brightly. I have it connected to RCA inputs, so I don't know if it would happen using the antenna input, but based on your experience, I suspect it would. I never got around to calling tech support, and my return period ends in two days, so it's going back to the store tomorrow.
Oct 30, 2011 | Coby Televison & Video
"on" light flashes twice and then "blacks out"
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
