Question about Toshiba Tecra 8200 Notebook
My toshiba tecra 8200
My toshiba tercra 8200 will not boot up. the cd works but nothing else...and the cd rom only worked when i booted up or shut down the computer before this.
it did this before( wouldnt boot up) but all i had to do is restart the computer once or twice and then it worked fine but now it doesn't work at all. all the right lights light up when i try to boot up but i dont hear a hard drive spinning or any fans running..just the cd rom running
Hello! i have a laptop,Toshiba Tecra T9100.The Cd-rom is not working and i whant to reinstall the windows from usb boot-able. in BIOS i cant find nothing like boot from USB! HELP!!!!!!
press f8 as you on the laptop and you will get the " select boot device " menu. here you can select the usb drive.( keep the drive connected before you on)
May 16, 2011 | Toshiba Tecra 9100 Laptops
How do I get my Toshiba Tecra to boot from CD
Please restart the computer and press the F2 Key to enter BIOS Setup. Then follow the onscreen instructions to locate the Menu for Boot Configuration to select First Boot Device as the CD-ROM Drive or DVD-ROM Drive. Then select F10 Key to save the changes and Exit. Now insert any bootable Operating System Disc and restart the computer to boot from the CD.
Mar 27, 2011 | Computers & Internet
I inherited a Toshiba Tecra 8200 laptop. It boots to a black screen asking for a password. Is there a way around this? Thx
Hi, try pressing the ESC button during boot up, this will allow you to start in safe mode, from where you can change your passworg, via the control panel. (Sometimes its the Del button on sertain machines)
Jul 05, 2010 | Toshiba Tecra 8200 Notebook
Toshiba Tecra A3X Not Booting from USB CD ROM
Your laptop is apparently unable to boot up off an external usb source. Only newer equipment has this provision in the bios. Since you cannot boot up from usb the only way you can recover your unit or do a clean reinstall or repair of xp is to replace the internal drive that is allegedly defective.
Replacing the optical drive is fairly easy and does not involve massive disassembly of your laptop. And any cheap drive will work provided it has the same physical configuration as the old one.
Jul 03, 2009 | Toshiba Tecra A3 Notebook
My Toshiba Tecra 8200 Boots as far as Wallpaper and then freezes and nothing will start it Colin.
try booting it in safe mode if it boots restore your pc to some back date where its working fine
Jun 14, 2009 | Toshiba Tecra M1 PC Laptops
Toshiba won't boot
 You can boot from XP cd.
When [R] this will launch recovery console.
Choose your windows installation (typically by pressing [1] press return..
When prompted for password type chkdsk /r
Press return..Windows will fix errors..type Exit and press return..
Let me know if that helps.
Jan 05, 2009 | Toshiba Tecra A8-S8314 Notebook
Toshiba tecra will not boot up
Your motherboard is the issue here I have seen this problem many times but just to make sure try hooking it to an external monitor
Dec 08, 2008 | Toshiba Tecra 8200 Notebook
Disck error
Generally the hard drive, not the motherboard.
Aug 12, 2008 | Toshiba Tecra 8200 Notebook
Toshiba Tecra 8200 Notebook Logo
133 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
